Auto trans delay engaging followed by thump 02 S60
seanjm
Year and Model:
Post by seanjm »
My 02 S60 with 65000 mi has a consistant problem with the transmission getting into drive. Either from N to D or P to D. It sometimes has up to a 2 to 3 second delay and then a thump into D. Does not seem to matter if it is warm or cold when this happens. Any ideas out there?
2002V70
Year and Model:
Post by 2002V70 »
My '02 V70 does the same as well but only going into drive on a cold morning. I think it is one of the solenoids that have gone bad. They are accessible from under the side cover.
It may be wise to flush the trans fluid before trying anything else. Make sure you use the proper fluid. Go to the Toyota dealer and buy a case of their "Type 4" fluid. About $6.00 per liter there as opposed to $20.00 each at the Volvo stealership. Same fluid. Same manufacturer, Exxon/Mobil.
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
You can get the proper fluid at the Toyota dealer and also on line...just make sure that for your car you use JWS-3309 compliant fluid.
fozzi19
Year and Model:
Post by fozzi19 »
How much do solenoids cost to replace...
