Hello
I am experiencing a very annoying problem with my 1999 6 cylinder non turbo S80, most of the time the throttle has no response whenever i press on the accelerator and other times it works just fine but with slow throttle response i put it on vida dice diagnostic cable and this is what i found:
https://imageshack.com/i/expYUdPkp
https://imageshack.com/i/iprABUHip
i have had the following done with no use:
changed thee alternator
changed the throttle
changed the tps on the throttle with contactless one
changed the accelerator pedal
the car seems to work for couple of days whenever i disconnected the battery for five mins but then the problem comes back again and also I noticed that the accelerator has no effect (no throttle response) when pressed at the same time when pressing the brake pedal , not sure if thats normal
1999 S80 No Throttle Response
- christophervolvos80
- Year and Model: 2000 Volvo S80
I had a similar issue and brought it to my mechanic. He claimed it was my mass airflow sensor and had it replaced. He did clean the electronic throttle body as well. Since then I have had no problems so far, and it has been about 3 months.
Thanks,
ChristopherVolvoS80
ChristopherVolvoS80
- 21 Replies
- 5339 Views
Last post by precopster
- 14 Replies
- 5130 Views
Last post by mrbrian200
- 3799 Views
Last post by rspi
- 672 Views
Last post by ignatz
- 1020 Views
Last post by oragex
