1999 V70xc What the Heck is Happening with this Car
flyingd
Year and Model: 1999 XC V70
Post by flyingd »
I am getting different lights lighting up my dash. First the dreaded blinking arrow, then the Check Engine along with the blinking arrow, then the ETS joined them. Then the blinking arrow went off, then the ETS went off and left the Check Engine light the only light on. I am going to get the codes read today, but can anyone tell me what the Heck is Going on With this Car!!!!!!
1999 V70 XC 135K
chrafael
Year and Model: 1998 v70 GLT
Been thanked: 10 times
Post by chrafael »
Give us the codes, it'll help.
flyingd
Post by flyingd »
Just got them
P0741
P1618
1999 V70 XC 135K
flyingd
Post by flyingd »
Need a little help here.
1999 V70 XC 135K
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
1618 is a communication error code
You may have a short or a wire that's frayed, have fun, it's a nasty code
It also can just be an ABS code needing a new/rebuilt module.
($70 from Matt, you should ask him what to look for first
His email: [email protected].
Fogducker
Year and Model: 850AWD 1997
Post by Fogducker »
Check your voltage reg in the alt... ;-)
JRL
Post by JRL »
Nothing to do with that code
Fogducker
Post by Fogducker »
Might not have anything to do with the code but the dash light problem is similar to a voltage regulator problem so I was just throwing it out there...........? Perhaps you could elaborate on what the problem actually is?
Been thanked: 4068 times
P0741is a torque converter code...ergo the flashing arrow. I dont know a lot about slush drives so others will need to chime in.
JRL
Post by JRL »
abscate wrote:P0741is a torque converter code...ergo the flashing arrow. I dont know a lot about slush drives so others will need to chime in.
That would mean the tranny is probably shot but change the fluid on that one.
The 4 speeds are tough and it may go away after a fluid change
Fogducker wrote:Might not have anything to do with the code but the dash light problem is similar to a voltage regulator problem so I was just throwing it out there...........? Perhaps you could elaborate on what the problem actually is?
I can't, you have to start fault tracing wires. As I said check with Matt on this one first
http://www.check-engine-light.com/trouble-codes
