Hello, I live out in Southern California and we don't get very much bad weather. Recently I was caught and drove through a thunderstorm that produced a flash flood across the road that was at least 8-10 inches deep. I did not get flooded out and was able to keep going at about 3-5 mph, three other cars were not so lucky. After getting out of the flood area I opened the hood just to check if everything looked okay. Since I do not have an under engine protection pan (or splash pan), my engine bay and top of motor looked like someone threw chocolate milk everywhere! I'm now in the process of cleaning the engine bay and have already ordered the new protection pan and bolts.
My questions are:
1) What are the possible components that could be affected (like the alternator and fuse/relay box) if they were to get extremely wet?
2) What causes this plastic protection pan to get damaged and rip off?
3) Are there any better alternatives in aftermarket protection pans that are not plastic or at least stronger?
Thanks!
2000 S80: Under Engine Protection Pan
- christophervolvos80
- Year and Model: 2000 Volvo S80
- The new under engine protection pan I ordered from RMeuropean for $135.
- engine_pan.jpg (66.39 KiB) Viewed 1198 times
Thanks,
ChristopherVolvoS80
ChristopherVolvoS80
Sometimes people just take them off and never put them back on. They're pretty durable, mine (from a 2000 also) doesn't seem to have cracks or anything, but it is plastic so I'm sure it's possible to just rip it off accidentally
Don't quote me on this but I *believe* IPD might have an aluminum pan that bolts right on
And the fuses/relays are at the back of the engine bay nearest to the driver, they don't typically have issues with moisture but it's probably worth at least opening the cover to see what it looks like
I'd spray the starter, alternator, and ETM connections with a bit of wd-40 just to displace the water
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
It's a good idea to let the alternator dry for a while (if weather permits).
The plastic shield is good in situations when going over debris on the street, so components such as power steering lines don't get damaged.
- 13 Replies
- 2804 Views
- 1722 Views
Last post by cn90
- 15 Replies
- 2621 Views
Last post by vovo850
- 23 Replies
- 3958 Views
Last post by Faust
- 557 Views
Last post by SuperHerman
