96 volvo 850R ABS Module wiring w/pics
96 Volvo 850 R ABS Module Wiring w/Pics
Ben850
- Been thanked: 7 times
Re: 96 volvo 850R ABS Module wiring w/pics
I'll drop in another and test continuity on the wiring while I'm in there.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
Ben850
I looked closer at the wiring to the wheel sensor and noticed a splice like the one I had done to the severed right side last year.
I cut out the splice and re soldered the wires. The condition of the metal inside the casings seemed corroded and powdery.
Took it for a drive and it worked for a bit and then stopped again.
I bought some electric contact cleaner since I had just ran out of it. Removed the junction at the ABS module and sprayed the terminals of the harness liberally. Also blasted the pins at the module.
It is back to life for now so I'll take it to work tomorrow and see how it does.
- phils94850
- Year and Model: 2009 s60 turbo
glad you got her fixed ben..
1996 Platinum Edition
Ben850
I wish I could say it was fixed though.phils94850 wrote:glad you got her fixed ben..
"Working", yes, but intermittent failures requiring turning the car off and restarting.
I did a bit of light reading last night. I forgot for a moment I have the service manual. I have boiled it down to a few possibilities I haven't yet checked.
Within 15 minutes of reading, I was amazed how much I had learned. I only have about 430 pages left to read and retain.
I will update with results.
Matty Moo
- Year and Model: 850, 1996
- Been thanked: 30 times
You need to get that vag-com cable so you can use Vol-fcr.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
Ben850
That came in the mail two days ago.Matty Moo wrote:You need to get that vag-com cable so you can use Vol-fcr.
I've been working non-stop the past two weeks and have had no time to do anything.
Sunday, everything should come together.
Have the VAG-COM.
Have Service manual.
Have software.
Spare parts, tools. I've got.
Some time to focus on the task at hand will be nice.
