Hi all,
I have a strange issue with my 2007 V70, the right (passenger) drive axle is coming out of the transmission case by itself (about 1/2").
Probably that a circlip (snap ring) would be missing but where is it ? Is it the one inside the CV joint boot (inner) or that hold the axle in the transmission ?
2007 V70 Right drive axle popping out of transmission
Thames
- Year and Model: 2020 S60, 2006 S60
Now member of the Wagon Mafia!
V70 '07 "The V"
XC70 '05 "Grizzly"
S70 '99 LPT "Blackie" -- departing soon
S70 '98 NA "Pearly" -- SOLD
740 '90 B230F "Rusty" -- SOLD
and some Gibson, Fender, Marshall,... but it's another thing... !!
V70 '07 "The V"
XC70 '05 "Grizzly"
jimmy57
- Been thanked: 322 times
There is no circlip on RH side. The bearing on that side that is carried by the retainer bolted to engine block is what holds the shaft into transmission.
Thames
Thank you mate, I got similar information in the last hours... I will remove the 2 nuts and inspect the bearing.
If the bearing is bad, I guess I'll have to remove the entire shaft, slip (read :press) a new bearing into place and put it all back in ?
V70 '07 "The V"
XC70 '05 "Grizzly"
V70 '07 "The V"
XC70 '05 "Grizzly"
jimmy57
The shaft should have no left-right movement beyond a few hundredths of a millimeter. The bearing does press on and is is likely not shown as serviceable but it is the same bearing as many of the 240's and 740's used as the middle of the rear driveshaft support bearing.
Thames
I removed the bearing support yesterday and the bearing itself is loose on the shaft, and of course, displaced.I cant slide it back in its original position, so we will have to remove it and put a new one back with press. My mechanic has done it recently on a V70R and all went fine.
V70 '07 "The V"
XC70 '05 "Grizzly"
V70 '07 "The V"
XC70 '05 "Grizzly"
