Volvo 850 Oil Sump O-Ring Kit
Baptiste1106
Year and Model: 850 1994
Post by Baptiste1106 »
My Volvo 850 turbo has the ticking from the top of the motor. Was told top end is being starved of oil from worn/damaged o-rings from inside the oil pan. Ok purchased the o-ring kit for &14.95 from fcpeuro.com. I've looked at multiple DIY to remove the oil pan ok. Now when i do remove the oil pan, which o-rings/gasket am I replacjng ? Please mention part# from image provided, thanks again
Oil sump o-ring kit from fcpeuro.com
Which O-Rings am i replacing ?
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
The kits have more stuff than you need. The ones you will be changing in the sump are 7, 15, 20, and 29. You will also need the anaerobic sealer.
While you are there, clean out the square port from the PCV real well.
