Volvo 850 Oil Sump O-Ring Kit
Baptiste1106
- Year and Model: 850 1994
- Been thanked: 2 times
My Volvo 850 turbo has the ticking from the top of the motor. Was told top end is being starved of oil from worn/damaged o-rings from inside the oil pan. Ok purchased the o-ring kit for &14.95 from fcpeuro.com. I've looked at multiple DIY to remove the oil pan ok. Now when i do remove the oil pan, which o-rings/gasket am I replacjng ? Please mention part# from image provided, thanks again
- Oil sump o-ring kit from fcpeuro.com
- image.jpg (194.49 KiB) Viewed 1211 times
- Which O-Rings am i replacing ?
- image.jpg (81.79 KiB) Viewed 1211 times
- Year and Model: Many Volvos
- Been thanked: 76 times
The kits have more stuff than you need. The ones you will be changing in the sump are 7, 15, 20, and 29. You will also need the anaerobic sealer.
While you are there, clean out the square port from the PCV real well.
- 1388 Views
Last post by crussell83
- 3151 Views
Last post by 93Regina
- 683 Views
Last post by Sveedy
- 1200 Views
Last post by theWIFES_S70
- 11 Replies
- 3650 Views
Last post by Krons
