Will this Vida - Laptop set up work?
How to buy, install and use VIDA, VADIS, DiCE, VMWare and all the questions and answers that come with these tools.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2654 times
Been thanked: 1247 times
Re: Will this Vida - Laptop set up work?
Post by matthew1 »
If a VM needs drivers, they're for the VM, not the host machine. But I can't speak directly on the subject of DiCE drivers because I've never run it.
The host's hardware is available to the VM as though the VM was the native/only operating system on the hardware.
VM's typically don't know they're a VM. They think they're the OS.
Also -> Amazon link
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
2010D runs fine on 32-bit XP Pro (I run it). I didn't like lower stability of newer VIDAs, which also require 64-bit Win7 (I had it too), and went back to older version, which is still good enough for my 2002 V70 and 2005 XC70.
DiCE didn't work inside virtual machine running under Linux KVM, either USB passthrough doesn't work well in KVM or DiCE driver does weird things.
