2002 xc70 Dash Problems
I have a 2002 XC70 with 93000 miles. Lately the dashboard has been doing some really odd things. The trip meter resets itself randomly back to 0 or will reset to something outrageous like 850 miles. The clock changes time on it's own, and the high beam indicator only works intermittently (bulb was replaced recently). It seems to do this wacky stuff when I have turned the car off and then restart the car, which could be a day or two later. Has anyone else ever experienced this and if so, what is the fix? A Volvo dealer told me a new dash would cost about $1000 plus the labor. Not sure I want to spend that much but I sure would like to know what is causing this and what the fix is. Thanks very much!
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
This is a common failure on these cars. It's not "if" it fails - it's "when" it fails.
This is probably the most popular fix to the problem (About $450 + core charge):
http://www.xemodex.com/technologyimprov ... for-volvo/
Or anther possible fix, the way I chose to go, is to source a used replacement from a knowledgeable Volvo wrecking yard like Erie Volvo or Southern Vo-vo. They know how to match the code numbers on the back of the DIM to work with your car. The drawback with this option is that the odometer will likely set to that of the donor car (mine did) and the warranty will be limited. (About $125-150)
Remove/replace videos are available on Youtube or the Xemodex website. Tip: Do NOT turn on the ignition switch when there is no DIM connected or it will trigger the SRS warning light which can only be extinguished by the dealer or someone with the proper diagnostic computer. Please don't ask me how I know this.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Xmodex got terribly expensive, but there are also plenty of ebay sellers for the fix
http://www.ebay.com/itm/VOLVO-INSTRUMEN ... c9&vxp=mtr
Thank you to chrism for his post regarding xemodex. This the route we took and we couldn't be happier. Yes, they are pricey but the customer service was great, the part was received quickly, works perfectly, and when they received our DIM they refunded the core charge almost immediately. Thanks again for the info, you saved us a lot because our next move would have probably been the dealer which was going to be over $1000 plus labor.
In addition to the dashboard acting kind of funny (clock runs away, sometimes can't dim the dash) my radio has a mind of its own sometimes. Changes channels. Bang on it, changes channels. Try to adjust channel, nothing! etc. Is this all related to the DIM? If I fix the DIM will it fix my radio? How about my very strangely acting automatic windshield wipers? Sometimes run when dry, sometimes don't run when raining, etc. Love my XC70, but a little confused by it at times.
John
2004 C70 Ragtop w/2.4L LPT 65K miles (wife dd)
2003 XC 70 with 2.5L Turbo, 195K miles (my dd)
Parts Car: 2000 C70 Ragtop w/2.3L Turbo, died at 200K miles (water pump siezed. took out timing belt)
- 915 Views
Last post by hypo
- 234 Views
Last post by 5rivers
- 1915 Views
Last post by aethera
- 9 Replies
- 1728 Views
Last post by 850 LPT
- 584 Views
Last post by GrapeApe123
