I am looking for a new set of steel rims for my 16" snow tires. I bought my last set of OEM 15" steel wheels from Volvo for my '95 850 but now I have learned that there isn't an OEM 16" steel wheel available for the 850 series vehicles, but there are 16" steel wheels available for the S70's...can anyone confirm if these have the same bolt pattern and offset as the earlier 850 models? I believe the specs for both vehicles are the same (16x6.5, 108 mm bolt pattern, with a 43mm offset). I could not get the parts department at two Volvo dealers to confirm this for me.
I really want to use OEM because I had issues with an aftermarket set in the past.
1996, 850 Turbo, 16" Steel Wheels
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
Hmmm, I looked for 16's a couple of years ago for my V70 and couldn't find them anywhere. I now run the winters on a set of 15 steelies and they've been fine. 15 should fit if you don't have the big 302 brakes installed. There's lots of 16 inch alloys available on craigslist, cheap set might be an option.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
- Year and Model: Lots
- Been thanked: 128 times
I've been lurking here for around 4 years now and I've never heard of a 16" steel wheel for S70s. The wheels on any Volvo P2 series have around 43mm offset (unless they're from a 2004-2007 R series) with 65.1mm bore and 108mm PCD.
I'm running 2001 or 2002 XC70 16" alloy wheels (with 205/50s) on my 2000 V70 and they look, fit and drive just fine. These cars also share the same basic suspension setup as an 850 so pretty much anything goes on 850s unless it's an early 4 stud.
Thanks for the info. I haven't call on these but Volvo Parts Webstore had this listed for a 2000 s70. They are listed at approx $90 each. Based on your comments I should be confident that 16" S70 wheels will be a fit for my 850.
WHEEL.
Stock Code 9173248
Manufacturer Volvo
Categories Wheels and Wheel Hardware > Wheels, tires, hubs
Assemblies Wheel equipment ( 6.5x16"); Wheel equipment ( 6x16"); Wheel equipment (6.5x16" )
WHEEL.
Stock Code 9173248
Manufacturer Volvo
2008, C70, 44,000 miles
2000, S70, GLT, 67,000 miles
1995, 850, GLT, 144,000 Miles
1996, 850, Turbo, 226,000 Miles (TMU)
northernlights
- Year and Model: 850 Turbo 1994
- Location: Florida and/or Raleigh NC, depending on the day
- Been thanked: 8 times
Rockauto lists this part number for a 1998 and up S70, although it's not cheap - $95 each reconditioned.
91732487
91732487
I purchased four Volvo 16" steel wheels and had my snows mounted, balanced and installed on the car. I did not purchase wheel caps. Besides appearance, is there any reason why I should install wheel caps? I don't care how it looks and want to save the cost of the caps unless they offer some protection that I am not aware of.
shaker_chi
- Year and Model: 94 850, 98 S70T5 M
- Has thanked: 3 times
- Been thanked: 3 times
Do the 16" steelies from the 960/940 fit the 850/s70?
- Has thanked: 311 times
- Been thanked: 817 times
The wheel covers (hubcaps) are purely for esthetics. If you don't want 'em, you don't need 'em.
JRL
- Year and Model: Several
- Been thanked: 16 times
They made them, I had them on my 850R (steelies w/ hubcaps and snows).
Same wheel for an S70-V70
db130
- Year and Model: 2002 V70 T5
Part number 9173248, a 16x6.5" steel wheel with +43 offset. I have had 2 sets of these 16" steel wheels during my Volvo ownership and can personally vouch that they clear the 302mm rotors.
There's also a 16x7" Volvo steel wheel with +49 offset that also supposedly clears the 302mm rotors(but this was 2nd hand info), I usually see them paired with S80 tire sizes.
2002 V70 T5 169k
2002 V70 NA 249k
2006 Mini Cooper S 90k
2002 V70 NA 249k
