Hey guys,
been meaning to post about this for a couple weeks, just been super busy. The ABS and TRACS Off lights have been coming on in my car intermittently lately. The strange thing is that I don't think it's the sensor, because occasionally when driving, I'll hear a buzz, sorta sounds like a duck sighing, and then the lights will come on. If it happens that I've got my foot on the brake, it also pushes back, and the brakes seem like they go out for a split second, then the lights pop on, but the brakes are back to what seems like normal.
Anyone have any experience with this? Is it the ABS module? I know they can be a problem on the v70, in fact I told my sister I would re-solder hers before winter this year. Thanks!
96 855t, ABS/TRACS lights, weird buzz and pedal feedback
futureboycolin
- Year and Model: 1996 850 Turbo Wagon
1996 855T, "Ol Burgie"
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
I'd clean the sensors and reluctance rings on the front axles. Sometimes they'll get so much crud on them they stop working.
It sounds like the ABS system is activating, then getting a bad reading from one of the sensors, then putting itself in limp mode. When ABS shuts off, you'll still have normal braking power - they'll just lock up if you press too hard.
'98 S70 T5
2016 Chevy Cruze Premier
futureboycolin
Thanks Justin, I'll check those.
futureboycolin
Can I clean the reluctance rings and ABS sensor with carb cleaner? Or just hitch a ride to autozone and grab some brākleen?
I checked out the sensor connections and they seem fine. Is there a way to clean the sensor itself without removing the calipers? The left front bolts would NOT budge. May have to come back at them with heat in a few days.
Update: got some Brakleen. Disregard the carb cleaner. Cleaning the rings and the sensor. Will update if it fixes the problem.
jblackburn
Carb cleaner will work just fine. A toothbrush might get in there without removing anything.
'98 S70 T5
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
Futureboy: I have the exact same problem. It only happens once in a while; normally, the SRS light is always on. The previous owner said he replaced the computer so I still need to check my sensors which I am planning on doing once I change to winter tires. ABS on old cars in a PITA, (you fix one sensor and the other fails), so I've learned to just live with it for now.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
- 5344 Views
Last post by oragex
- 22 Replies
- 5803 Views
Last post by hausmeister
- 1741 Views
Last post by CDoore54
- 309 Views
Last post by rsmigel
- 9 Replies
- 687 Views
Last post by bmdubya1198
