Amazon have these Bosch # 0261230018 for $79.34 and they even ship them to Oz!!
1998 V70 XC P0108 Barimetric Altitude sensor code
- Year and Model: Lots
- Been thanked: 128 times
I have the same code on my newly aquired '98 V70R so I'm watching this thread like a hawk.
- Has thanked: 2210 times
Well no clear answer precopster sorry. Apparently the check light has stayed off for the last week since being reset. Checked it today and no code showing. I swapped the part with the used one I salvaged, and so far it is also not throwing a code. Cleaned the contacts just in case of the clip, and the A/C pressure switch.
However, (I have just posted another question on leaky oil lines) I noticed there is a leak from the oil cooler lines and the acceleration sensor is right in the firing line. Perhaps leaking oil is to blame. Again, I'll update once I get a chance to check it out.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
The 99 and later with ME7... have the part on the circuit board inside under the cover not visible unless you pry tabs and take cover off.
The sensor does very little but altering base fuel trim for altitude is a better solution than to let long term fuel trim (LTFT) take the job. If you alt compensate then the parameter range for fault detection for LTFT can be a smaller window and detect issues sooner.
Accel sensor is used to rule out bumpy roads as the source of crankshaft speed irregularity for misfire detection. Early method was not sophisticated enough to know the difference between flywheel speed irregularity due to misfire or wheels bouncing off pavement and then landing again.
Education is much appreciated jimmy57! You never seem to know everything about Volvos and their strange quirks!
Many thanks,
Many thanks,
- Has thanked: 1611 times
- Been thanked: 4073 times
Jimmy57 is an extraordinary resource got all things volvo, indeed.
Thanks again, jimmy57
- 134 Views
Last post by Vova585
- 707 Views
Last post by gdict
- 1347 Views
- 673 Views
Last post by C30_ZA
- 9 Replies
- 7352 Views
Last post by soundhertz
