Anyone have any idea? Could this be coming from the turbo hose? Thanks.
1999 s70 t5 coolant leaking from rear.. video
kahl
- Year and Model: 2000V70XC
- Been thanked: 10 times
I would follow the coolant line from the overflow bottle to the back of the engine. From there you will see a 4" hose connected on both ends with tubing. Check this hose. Then continue to follow the metal tubing you will see that there is a 90 degree hose on the back of the engine by the turbo? These two hoses have leaked on my turbo cars.
- image.jpg (272.42 KiB) Viewed 934 times
- Year and Model: Many Volvos
- Been thanked: 76 times
The 45 degree line with two different diameters is the usual suspect. It isn't a picnic to change but it is doable. I've found that removing the banjo bolt from the rearmost connector on the turbo simplifies the process.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I would put someone's money on either the hose from the back of the motor to the heater core junction or the lower radiator hose.
speedyt5
- Year and Model: s70 t5, 1999
- Been thanked: 2 times
Shop says it is both the hoses going to the heater core, as well as one of the hoses to the expansion tank has a small leak as well as the lower radiator hose has gotten oil on it and has a huge bulge and is ready to go too. Anyone want to loan me some money?
- Been thanked: 4064 times
Volvo parts only on these please. Specifically, avoid URO hoses on these critical parts. Park your car until you have enough gelt for the Volvo hoses.
- rspi
Contact rspi..
The junk yard is full of decent hoses. They can hold you over till you get new ones. Replace them one at a time starting with the one that is leaking. Hell, you could have purchased all of those hides for the cost of the dealer diagnosis fee.
- Been thanked: 504 times
I don't know about 1999 setup, but I did my 1998 S70 coolant hoses, see link below.
Use ONLY Volvo genuine hoses, they are cheap anyway!!!
https://www.matthewsvolvosite.com/forums ... hp?t=55306
