98 S70 Driver's side door will not open
dallasrules
- Year and Model: 1999 v70 xc
I had this problem on my 97 v90. There is a plastic piece that connect the rod to the door handle and they break. The door won't open from the inside or the outside. I had this happen on more than one door. The pieces are cheap if you can find them on ebay, but otherwise they seem only to come with the door handle. Can't help with getting the door panel off, but once you do, swap the plastic piece with one of the other doors so that the drivers door will work until you can get another piece. Hope this helps.
- 762 Views
Last post by Vova585
- 6105 Views
Last post by Gjendems
- 2644 Views
Last post by chrism
- 2173 Views
Last post by mrscullini
- 6640 Views
Last post by transpalette
