If my sensor is telling me to replace my key FOB battery, and if it goes dead, will the car still start if I put the key FOB in the "inserted slot" on the dashboard?
Someone also mentioned to wrap my key FOB battery in aluminum foil, what does that do?
2008 S80 Sensor says replace key battery
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
yes.
I have no idea what the aluminum foil would do. That is a weird one. The security ID chip in key is not powered by the battery, only the remote radio that is active when the buttons are depressed. Even the keyless entry system (if the car has that feature) requires no fob battery as it is another security chip that is read when you grab door handle or trunk handle.
The lock and alarm status indicator LEDs on the keyless system remote also need battery to operate.
- 5138 Views
Last post by Raindog92
- 1422 Views
Last post by db130
- 4498 Views
Last post by JacksonTNTurbo
- 19 Replies
- 5816 Views
Last post by MoVolvos
- 86 Replies
- 23255 Views
Last post by herbakis
