1995 850 t5-R
Forum rules
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Re: 1995 850 t5-R
September 1, 2014 - 222,765miles
Replaced cruise control pump with new used unit.
polskamafia mjl
October 9, 2014 - 223,889miles
Reinstalled front bumper.
Removed driver side wheel well liner (needs to be replaced along with passenger side liner).
Rotated tires.
Rotated tires.
polskamafia mjl
October 11, 2014 - 223,948
Adjusted driver's side e brake shoes after they started smoking while driving.
polskamafia mjl
October 30, 2014 - 224,554miles
Replaced instrument cluster with new used unit (old cluster had intermittent problems with gauges).
Replaced both odometer gears w/in cluster.**
Replaced 4 main back light bulbs along with 2 bulbs for clock/info display.
Swapped several indicator bulbs over from the old cluster.
** When removing face plate on turbo 850's, first remove the 8mm nut securing the boost gauge to the back of the cluster.
polskamafia mjl
October 31, 2014 -224,XXXmiles
Discovered that I swapped in a cluster from a later year 850. Speedometer does not work, the transmission arrow is flashing, and the ABS light is on. ::sigh::
polskamafia mjl
November 1, 2014 - 224,XXXmiles
Replaced radiator
Replaced coolant with Zerex G0-5
Replaced turbo return hose with IPD silicone hose
Replaced master fuel pump relay
Attempted to replace turbo inlet hose; decided to wait until Spring when the weather gets warm again
Noticed damaged vacuum hose running from vacuum tree to turbo
Replaced radiator
polskamafia mjl
November 4, 2014 - 224,XXXmiles
Spliced in temporary vacuum hose to repair damaged hose running from intake manifold to turbo; will replace entire hose when the weather gets warm again.
polskamafia mjl
November 6, 2014 - 224,XXXmiles
Inspection and Emissions completed at Monro Muffler/Brake
polskamafia mjl
November 18, 2014 - 224,XXXmiles
Completely loosened driver side e-brake shoes due to them binding up and not releasing correctly when I released the e-brake lever.
polskamafia mjl
November 23, 2014 ~ 225,281miles
Replaced wiper relay with IPD adjustable relay
Tightened torx screws securing sunroof
