1996 850 GLT Cabin Air Filter
joe_pinehill
- Year and Model: 850 1996
FCP sent an email with MANN filters on sale. I ordered engine, cabin and oil. The cabin filter does collect a lot of debris. The filter was only about 6 months old. I can see it protects the interior workings of the AC/Heating system more than cleaning the air for passengers.
96 850 GLT
RIP '90 240 DL, 285K, someone ran a stop sign in front of me
RIP '89 760 Wagon, 200K
RIP '83 240 Wagon, rusted out
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I agree with that! I'm always surprised how filled up the cabin air filter gets after 3-6 months. It can plug really quickly in spring and fall here when the trees pollinate and shed seeds.
I've taken to buying large house-sized HVAC filters from the big box store and then cutting them down to make my own cabin filters. I cut long strips and then squeeze the pleats closer together than they are in a typical HVAC filter, to mimic the pleat density in the official cabin filter. You can make a lot of filters that way for a few dollars.
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
I need to do my XC90 soon. I just changed the one in my S70, it was last changed at 56k.... in Oct 2002
It was a paper filter, but looked like a carbon filter
these cars can survive just about anything.
Current Volvos:
- Has thanked: 311 times
- Been thanked: 817 times
I'm interested in this. What material are you talking about; maybe a link to a pic of one of those filters?jreed wrote:... I've taken to buying large house-sized HVAC filters from the big box store and then cutting them down to make my own cabin filters...
- jreed
I have been buying the three packs of 20 inch x 30 inch air filters at Home Depot for about $8. I can generally get about 9 filters out of the three-pack.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Great idea. You can probably take 2 old filters and build both, install one, have the other ready, swap them out every year.
- jreed
You can remove the old filter media from a cabin filter. I strung some fine gauge copper wire through the frame to help support the filter media, but I don't know if it's necessary. You can probably skip it. Then get a big household HVAC filter:
Strip off all the cardboard and then cut the filter to the width of the filter frame. Use the wire pattern to keep your cut straight:
Fold up the media and place it inside the frame with the wire side down. I wrap the ends of the filter over the edge of the frame to make a good seal:
Wrap the edges with tape to hold the media in place and reduce leaks around the edge:
Reinstall the filter in the box. The frame has clips that fit into the box and hold it in place:
This could help save some money over time. I've been doing it for about 5 years, replacing the filter about every six months and it works well. Good luck!
This is a great tip, thanks jreed. I picked up some filters just for this (we have hydronic, not hot air heat).
stephansvolvo
- Year and Model: V70 GLT 1998
- Has thanked: 21 times
- Been thanked: 3 times
Very cool. I will give this a shot next change.
Stephan
84 240GL my first(sold)
88 240GL(timing belt killed it)
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
- 1513 Views
Last post by 454cid
- 10 Replies
- 3861 Views
Last post by BEJinFbk
- 1287 Views
Last post by brunocerous
- 1260 Views
Last post by rspi
- 1532 Views
