92 960 blinking up arrow, dead speedo. Searched
aStrauss
- Year and Model: 91 965 / 91 744
I have looked that over a bit. If I understand correctly, 311 refers to trans speed sensor, and 232 is differential speed sensor? I would like to get this right the first time, i don't want to go replacing incorrect sensors
aStrauss
From what I have seen of the gauge cluster and speedo itself, it should be functional so long as it has signal. However, the speedo is not working. That is the root of the issue, and I am trying to figure out how to correct it. I am also trying to make sure I am understanding the advice offered. I appreciate any patience you can spare, and concise, detailed responses. I think I am very close to having this all sorted out.
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
The Bentley Volvo 240 Service Manual (1983, 1984, 1985, 1986, 1987, 1988, 1989, 1990, 1991, 1992, 1993) explains it.aStrauss wrote:Can anybody better explain the use of a feeler gauge on the rear end speed sensor?
Speedometer Sensor Transmission Checked!!
not2old
- Year and Model: 67/81/89/89/92/95
I had this problem on my 1993 960. I had to replace the switch on the transmission, the push button switch near the shifter and the speedometer. All were defective. I don't remember where I found the information, but I was able to test the operation of the sensor in the differential with a meter. The wires are located under the floor in a wagon, near the spare tire on the left side. I may have gotten advice from my nephew who is a technician at a major Volvo dealership. I don't remember anything about a speed sensor at the transmission. This repaired the speedo and allowed the transmission to shift properly.
- 1160 Views
Last post by precopster
- 2601 Views
Last post by legalstuff
- 1473 Views
Last post by therealyogajoe
- 2495 Views
Last post by midimykeys
- 18 Replies
- 3163 Views
Last post by chitownV
