what is going on with timing tensioner roller quality ?
Ben850
Been thanked: 7 times
Re: Wow Ben . Did you read all the opinions expressed in the
Post by Ben850 »
johnnyfd wrote:last page and a half or so about the expelled grease ? Your statement is a direct contradiction to almost all of them and if I believed it this would negate all the reassuring knowledge I have gained from them :(
Alright. I may have just been getting tired of debating the issue.
I don't think I was contradictory to myself as much as to some other statements. A leaking Tensioner is definitely unacceptable. A bearing seal, I do not believe I would trust so much either, as to discuss how much it may or may not be leaking.
Second guessing is great unless it leaves you stranded.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
johnnyfd
Year and Model: 850T wagon 1996
Post by johnnyfd »
about what kind of outcomes result from these situations and I think it's been a pretty fruitful discussion considering how much experience and knowledge has been shared hear about it . Putting together all the information from this long thread bares some pretty strong conclusions about consistent outcomes in this kind of situation . That's a pretty big benefit for people like me who haven't had the opportunity to figure it out from direct experience . It's a great feeling to be able to make a judgement call for something so critical with a good amount of confidence . Anyone can say just replace it in this situation , but judging by the wealth of experience provided on this board , it sounds like you might have a very costly proposition of repeatedly replacing a bearing until you got one that never spun any grease out . And I mean costly time wise or money wise depending on whether or not you doing the work yourself .
Been thanked: 466 times
Post by cn90 »
Ben,
- I agree that leaking hydraulic tensioner is a serious issue. If one sees oil leak at the HT, replace the HT ASAP, do not forget the white plastic cap!
- On the issues of grease leaking from pulley bearings: I have seen it all, Volvo, BMW, Honda etc. you name it.
The last time I did the 98 S70 GLT Timing Belt @145K, the factory pulleys lasted 15y/145K w/o any issues. There was however a thin film of grease on the outside, which I assume was present there for the last 15 years.
Anyway, johnnyfd, just relax and periodically check that area, it is easy, only a 13-mm bolt.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Lol, we are still typing about this. Yes, we are board.
johnnyfd
Post by johnnyfd »
brands' pullies? I wasn't sure what you meant by "I have seen it all" .
obayha
Year and Model: V70 1999 Base
Post by obayha »
Four pages in as many of days! I need to go look at my TB change that I did close to 90,000 miles ago and check the grease. Did change everything at that time and the cover has not been removed again. I use this forum to learn and pass on anything I can from what I have learned. What I have gathered is a little loss in some things is OK, but not in others.
Now I will undo that massive 13 mm or 12 mm bolt and check it out. Maybe even take a picture.
I took into consideration the views of this forum on what parts to use in the TB change, and it must of worked.
Shane
1998 V70 T5 331,000 :( Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
mecheng
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
Ppl are definetly bored, instead you should Car Audio section and help me with my MP3 delima :D
My wife wants her radio back. I told her to wait, and you guys will help me :D :mrgreen:
See my earlier post, to reiterate, a bit of purge is okay and normal. How do I know? I designed and tested bearings for the auto industry at one point in my career.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
dosbricks
Post by dosbricks »
That does it! :D No more lawyering, you guys. mecheng is able to judge and has the final word.
Ben850
Post by Ben850 »
I honestly believe The answer could be calculated using the same technology we discern the air speed velocity of a north bound swallow carrying a 5 pound coconut.
Would that be an African, of European Swallow?
It is irrelevant.
A 5.oz. bird could not carry a five pound coconut.
No matter how long the runway.
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Hehe. Is lawyering when you lay down the law about something? Some of us do this regularly on MVS :D
I thought it was more to the tune of loitering : the act of remaining in a particular public place for a protracted time without an apparent purpose. :D
