This is the Whaler that was in my wagon last year. I had not realized it looked like this.
The car did sit for three months while the weather went to nearly 20 below zero.
A full level of Zerex mixed 50/50 with distilled water was in the system.
I did end up replacing the radiator after noticing drips at the time of the silicone plumbing upgrade.
So the thermostat and ETC were also replaced with OEM Valeo and Whaler without a second glance at the old parts until recently.
I don't usually throw out old parts for reference purposes. So, funny to see this.
Now that is a fail. Would that be a closed fail? Which could be catastrophic.
I understand the whaler fails open.
I have to believe this is freeze related and I was lucky to have been replacing everything anyway.
Anyone have a definitive on this one?
850 thermostat fail. OEM.
Ben850
- Been thanked: 7 times
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
- Has thanked: 312 times
- Been thanked: 818 times
Out of curiosity: drop it in hot water, does it still open?
Ben850
I suppose I could try that Eric, but look at the angle the frame had broken. I would imagine it holding a pressure unnatural to the original design. Logically, it would appear to be in a locked state.erikv11 wrote:Out of curiosity: drop it in hot water, does it still open?
I must fire up the Bunsen burner right quick.
No doubt, it is badly broken and probably broken shut, I am just curious what happens.
- Been thanked: 504 times
We see this all the time in BMW with 80K+ (broken tabs as shown).
Wahler makes very good tstat. I put them in my BMW and Volvo, zero problem at all.
After 80K, I replace them as preventive maintenance and when I remove them, no broken tabs.
For the records, I use strictly Prestone Green (refresh coolant every 3yrs or so) and zero problems during the last 25 years.
Ben850
Ok, that reaffirms what I've heard of Whaler quality. It was also comforting to see the Volvo logo and date stamps.cn90 wrote:We see this all the time in BMW with 80K+ (broken tabs as shown).
Back to my point of failure. It must have happened while immobile. It ran well indicating the 3 o'clock position until I had parked it for a few months.
I'm only curious. It caused me no harm.
Now cn. Which Bimmer won't put me in hock, but give me the driving pleasure of my meager Volvo stable?
So do these engines all have warped heads due to the stat not opening and overheating?cn90 wrote:We see this all the time in BMW with 80K+ (broken tabs as shown). ...
joe_pinehill
- Year and Model: 850 1996
I'm paranoid about thermostats. The first New car I bought was a 1984 Mazda 626, when I got out of school. My wife was driving it in '93 and she didnt pay attention to the temp gauge. Thermostat had failed close, car over heated, and the head warped.
Ever since, I have changed thermostats every other time I do a coolant flush. I'll feel really stupid loosing another car because of a $10 part.
96 850 GLT
RIP '90 240 DL, 285K, someone ran a stop sign in front of me
RIP '89 760 Wagon, 200K
RIP '83 240 Wagon, rusted out
Ben850
The reason I had even come across that thermostat is that it was in a box with the new one I was installing into the Sedan for this year.
I had driven the '93 n/a sedan the last two winters. It had not let me down but I noticed I could not get substantial heat in the cabin.
It is nice that the OEM whaler thermostats sell for about $12. The temp sensor, which I trust is SWF/Valeo , at $52. respectively but I believe it to be worth what it performs.
I had installed these in the Sedan last week an noticed the ECU immediately paying attention in a positive manor.
I can only imagine the winter heating issues will be done with as well. Throttle response had a noticeable difference.
This was not an endorsement for the supplier, but the only photo of the exact part I could find.
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I agree wholeheartedly with the above!
I am having much better results so far with the SWF coolant temperature sensor than I did with the aftermarket "FAE" brand. The FAE developed cracks in the casing and started to read higher temperatures than specification... took some pictures of that failure and posted them here:
https://www.matthewsvolvosite.com/forums ... =1&t=61920
I'm going to stick with the OEM SWF brand from now on.
- 2059 Views
Last post by Dmck
- 244 Views
- 26 Replies
- 10330 Views
Last post by wizechatmgr
- 1588 Views
Last post by Matty Moo
- 17 Replies
- 4311 Views
