VIDA DICE Interface Issue
How to buy, install and use VIDA, VADIS, DiCE, VMWare and all the questions and answers that come with these tools.
boboweb
Year and Model: V70 2002
Post by boboweb »
Hello guys - it is nice to find this place ;)
I just bought Vida Dice
http://aliexpress.com/item/2012-version ... 51618.html
but unfortunately i have this issue :
It pass all other tests except the interface test ! The tool did recognize the car (V70 2002) and it VIN number. But when i try to connect the ECU for diagnostics the options are grey and not avaible. The last LED of the tool "Vehicle interface status" stay grey !
I use Windows 7 , the tool is powered by the OBD2 connector (not external power source by adaptor) .
Can you suggest me any solutions for that issue ?
Thank you very much in advance !
mf70
Year and Model: V50 2006
Post by mf70 »
As had been mentioned in other posts, the interface test uses a special loopback connector, so, it will always fail.
Have you updated the DiCE firmware from the same source that provided you VIDA?
AFIK, they need to match. I would do this from the DiCE folder, not from within VIDA.
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
This is misinformation regrding Dice firmware needing to match the source folder. Leave the firmware alone for the time being; it won't cause a problem unless it's corrupted.
When you search for a car by choosing "read vehicle" and you can find your own car this means that the Dice is working correctly.
Once the vehicle is found choose the other options on the car such as engine, transmission, RHD or LHD then sun roof presence.
After this press the OK button (VERY IMPORTANT)
You should be able to then choose Diagnostics (it will read most modules and provide a summary) then " Vehicle Communication"
keng
Year and Model: S60 T5 2005
Post by keng »
Interface test not ok
Mind to share the solution of interface test not ok?
Windows 7 Ultimate, 2014D. Working well for many years. However, VIDA start act strange lately and dice cannot read my 2 cars. My dice unit used to work with Vdash as well.
Both VIDA and Vdash cannot read cars... It looks like something wrong with Dice.
I tried uninstall dice, restart laptop, reinstall, restart... no luck with it yet.
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 479 times
Post by jonesg »
keng wrote: 27 Dec 2025, 04:28 Interface test not ok
solution was given above, it will always fail that test, that doesn't mean its bad.
you could order a jrl or mongoose cable to use instead, they are tested.
here,
viewtopic.php?t=107529
