98 v70 awd, bolts for driveshaft balancing
wuttheheeck
Year and Model: 98 v70 awd
Post by wuttheheeck »
Hey all. I took out my drive/propeller shaft to replace the center bearing. As I'm reinstalling it I noticed that one of the bolts is longer. I know this is to balance out the vibrations. My question to you is how to I know where to reinstall said longer bolt? I'de like to avoid taking it to a shop but it might not be worth my time to try each location and then test driving.
Thanks!!
rmmagow
Year and Model: V70 1998
Post by rmmagow »
Give colorado driveshaft a call. I sort of remember reading someplace that that longer bolt really doesn't do much for balance. I think if you were to order bolts, you'd get them all one size. They should be able to give you a definitive answer.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
wuttheheeck
If that were the case I should be able to pick one up at the hardware/auto store. Ill see what they have to say.
instarx
Year and Model: XC70 T6 2011
Post by instarx »
wuttheheeck wrote:Hey all. I took out my drive/propeller shaft to replace the center bearing. As I'm reinstalling it I noticed that one of the bolts is longer. I know this is to balance out the vibrations. My question to you is how to I know where to reinstall said longer bolt? I'de like to avoid taking it to a shop but it might not be worth my time to try each location and then test driving.
Thanks!!
I would be amazed if you could tell any difference no matter where you put that bolt. I don't think its possible for those bolts to do much. First, the drive shaft doesn't turn that fast; and second, the bolts are only scribing a circle about three inches in diameter so none of them have much angular momentum. Third, the difference in the weight of the bolts is small. If the shaft were a high speed shaft it might matter, but it isn't. The only reason I can think that Volvo even does it is that it must be ridiculously easy to balance the shaft to a gnat's whisker when it is being balanced for the first time, so they do it.
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
Ozark Hillbilly
Year and Model: 2004 XC70
Post by Ozark Hillbilly »
I'll bet a cyber nickle that the factory didn't install an odd sized bolt with the intention of balancing a drive shaft..
Has thanked: 2200 times
Been thanked: 1852 times
I wouldn't worry too much about it. I have removed and replace prop-shafts on RWD and AWD Volvos and never worried about this. I asked the dealer mechanics and they had never heard about this. Volvo does (or did have) different part numbers for bolts, and there is a process for 'balancing' the system. But to be blunt, I personally think it is overkill. On a 3" diameter prop-shaft, the issue is not significant. It is more important to have a well balanced shaft with good U/J's, and center bearing/support.
I'm sure someone will come back and say I'm wrong, but I fitted a 1997 AWD prop into a 1998 V70XC and it was still running smooth after 4 years when I sold it. I still have the re-built unit in my garage as I never needed it.
