In search of a replacement of my failed blue box rear wheel bearing I found this Moog brand one on advance auto web site. It is the same as my blue box bearing (made by SKF), and only costs me $58 (with $40 off $100 purchase coupon)!
[img]IMG_1895.JPG[/img]
[img]IMG_1896.JPG[/img]
Moog rear wheel bearing hub
confused_al
- Year and Model: 1996 TLA wagon
Ben850
- Been thanked: 7 times
SKF is One of the most reputable of all. FAG, Timken, will also be a trusted choice in hub bearings.
All of which are in the $100.USD range. So your price sounds good. If it is a genuine SKF bearing that is installed.
Moog parts are refurbished. So You may not be sure of the bearing, no matter what the casting says.
Also, I do not see SKF stamped into the bearing itself, which I believe they almost always do.
EDIT: I have had no issues that come to mind with the Moog brand.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
- Been thanked: 504 times
FYI, eeuroparts dot com sells the REAR bearing made by SKF for $48:
http://www.eeuroparts.com/Parts/4404/Wh ... ar-271795/
Ben850
That is nice if you own a press and your existing hub is friendly.cn90 wrote:FYI, eeuroparts dot com sells the REAR bearing made by SKF for $48:
confused_al
That indeed needs a shop size press.Ben850 wrote:That is nice if you own a press and your existing hub is friendly.
Not sure about the bearing, but on Volvo's bearing it has no stamp eitherBen850 wrote:Also, I do not see SKF stamped into the bearing itself, which I believe they almost always do.
On the box it says "Made in USA", that beats any Chinese crap...lol
BTW, it is not cheap if not for that coupon:
https://www.amazon.com/Moog-512254-Wheel ... oog+512254
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
Ben850
With all that being said, Moog is a refurbished product.
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
Current price listed is $74. That's an increase of 54% in two years!!!! Geeze Louise!cn90 wrote:FYI, eeuroparts dot com sells the REAR bearing made by SKF for $48:
M1 10W-30 HM
M1 10W-30 HM
- 2430 Views
Last post by [email protected]
- 13 Replies
- 2610 Views
Last post by sleddriver
- 1111 Views
Last post by XCfella
- 897 Views
Last post by cuhfs
- 16 Replies
- 2721 Views
Last post by 98v70dad
