1998 S70 Drain and fill fluid
mar601
Year and Model: 1998
Has thanked: 34 times
Been thanked: 5 times
Post by mar601 »
If my S70 is on a level surface and I drain the transmission fluid, how much is going to come out (generally)? Seems to me last time I did it it was 4 or 5 quarts or so but I may be wrong. You have to flush to get it all out right? And something I understand you don't want to do on a car with high mileage.
Just want to know so I know how much fluid to buy -- thanks very much.
SpeedyPete
Year and Model: S70-T5, 1998
Post by SpeedyPete »
Hi when I drain and fill my 1998 S70 it usually takes about 3.75 quarts. Regards, SpeedyPete 8)
Has thanked: 311 times
Been thanked: 817 times
I do this in my garage a lot: almost exactly 3.5 quarts. But I still measure it every time ...
That's on jack stands, so not actually level.
mar601
Post by mar601 »
Yeah OK, thanks much -- I remember you drain it and then it gets to the point where it just drizzles forever. Think I'll just make a container and mark a line for 3.75 quarts and just do a drain and fill every oil change till it's replenished. It needs it.
And I'm reading Mobil1 Synthetic, right?
rspi
Been thanked: 72 times
Post by rspi »
I use the cheap stuff.
I also use the cheap stuff. SuperTech Dex III. If you have a turbo and drive it hard, then it will perhaps thank you for Mobil1, otherwise I really don't think it matters with these transmissions.
JimBee
Has thanked: 33 times
Been thanked: 43 times
Post by JimBee »
I got 4.5 quarts when I recently did this and it was soot black. That was two surprises: one b/c the standard amount is about 3.5, which is what I've gotten out previously; and also that it was so dirty after 3 drain and fills last summer. But that car hasn't been driven much in the interim and it was sitting on a slight downward facing slope. It's clean now.
JimBee
Post by JimBee »
