Perfect crank alignment for volvo s70
VolvoS70BASE
Year and Model: 1999 s70
Post by VolvoS70BASE »
Does any buddy have a clear picture highlighted of the crank wheel linedup perfectly someone keeps referring to bump on pully wheel aligned to block pointer how does the bump sit in valley I guess the easiest way is someone to highlight the picture of where bump should be in relation to notch on block
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
85 GLH, 367 whp
00 Insight, 72 mpg
Has thanked: 311 times
Been thanked: 817 times
VolvoS70BASE
I thought you have to align something on back of pulley wheel as we'll no one ever has a straight down view of back of wheel the valley and oil pump mark all aligned could you do a highlight drawning with that thanks
I don't really understand what you're asking for. What repair work are you doing, did you take off the crank pulley and need to put it back on, or just trying to time the engine, or something else?
Maybe post a picture of what you are dealing with, with highlighting to explain the question, etc.
Been thanked: 504 times
Post by cn90 »
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
He's asking for the pic of the crank including the harmonic balancer which also has a bump marking (the mark is not on the balancer but just forward of it on the leading edge of the crank pulley) that helps line up timing in a rough sort of way.
Obviously the small notches help with the finite adjustment and final check of timing.
The harmonic balancer's position is locating dowel at 12 o clock so the bump ends up lining with the oil pump mark. Once this is lined up it makes it easier to find the small notches.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
If he needs more than what Eric posted, he really needs a tow truck.
Perhaps the guy has bad eyesight or the crank pulley is rusty due to laying about which is causing the marks to be obscured
Perhaps he doesn't have a digital camera.
Asking for more info is always welcone here.
And here it is
And here it is
