Flashing check engine
- Year and Model: Many Volvos
- Been thanked: 76 times
The flashing CEL indicates a misfire which also matches your symptoms. Usually it is ignition but it could also be indicative of a burnt valve. Read the codes to see which cylinder is misfiring and then try swapping the coil for that cylinder with another cylinder and see if the misfire code moves along with the coil or if it stays with the cylinder.
- 989 Views
Last post by jbkeene
- 703 Views
Last post by gdict
- 2270 Views
Last post by Scholz
- 1210 Views
Last post by precopster
- 9 Replies
- 6325 Views
