DIY: 1998 V70 Axle CV Rubber Boots Tips/Tricks
Do It Yourself CV Boot Repair - Volvo V70
youropeen
- Year and Model: 2007 V70 R/2005 XC70
Both boots are torn on torn on my driver's side axle. I'm contemplating on getting a replacement and DIYing this job. Would I need to also replace this (http://www.fcpeuro.com/products/volvo-a ... -6843112-1) seal on the transmission?
- Has thanked: 311 times
- Been thanked: 818 times
I like to replace the seal when I pull an axle, unless I know it is relatively new.
You don't have to buy the Volvo brand to get quality on this part, it is just a rebranded SKF axle seal
http://www.fcpeuro.com/products/volvo-a ... al-6843112
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I replaced the axle seals on my '97 855 GLT a couple months ago at ~165k miles. I was working on an slightly sloped driveway. I was surprised how much transmission fluid leaked out on the downhill side -- it was probably 1 liter. On the uphill side axle, very little or no fluid leaked out when I pulled the seal.
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
The driver's side will loose fluid after axle is pulled.
My 2001 V70XC lost close to above 2qt in 24 hours while all 4 wheels were on jack-stand.
I will not rush to save, rather make it a simple D&F.
ps - I can not feel gear shifts up or down, only RPM reflects the change (@150K - this was 7th D&F in 2 years). Love it!
What those guys said ... yep, good time change out some fluid.
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
I was changing to my winter tires and it looks like I may be the exception to the rule, my drivers Inner Boot is leaking grease from a crack in the boot. Outer boot is fine. Volvo OEM axels, not sure if PO repalced boots. I used a syringe for Childrens Tylenol and squeezed in lots of lithium grease and then sealed it with RTV silicone sealant to buy some time. Heck, it might even last for a while as the inner joint doesn't flex much.
My local parts supplier is able to source the GKN outer boot for a 98 t5 (Part number 31256240) for only $20 but not the inner boot (PN 31256230). The Volvo dealer wants $59 for the inner boot; which might be worth it as I don't want to have to do this twice?
How is everyone's inner boot made by EMPI or Rein boot holding up?
Where are they made?
Not sure if the inner boot on the car now is GKN, I see Germany stamped on it. Could it be Rein? Maybe PO replaced it? Thanks
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
mecheng
Is their any write up on it, I see that you briefly mention it in one post but has anyone took the measurements? Why would they sell a different boot for the inner?cn90 wrote:You can use OUTER boot for INNER side.
Thanks
- 3615 Views
Last post by bmdubya1198
- 1326 Views
- 11 Replies
- 4543 Views
Last post by JimBee
- 2021 Views
Last post by sleddriver
- 4451 Views
Last post by ggleavitt
