installing third row seat on '97 850
papa_tom
Year and Model: 850 '97
Post by papa_tom »
allo...
i bought the set-up off e-bay and have the seat and belts installed. My problem is that I don't see how the latch works to keep it open ...or rather I have an idea how it works but i don't have anything on the back of the second row seats to receive the catch thingee from the third row seat back. So i'm wondering what other part is needed and perhaps what it looks like. When I got the package from the e-bay seller there were a half dozen or so extra parts i couldn't find a home for ...though none appear to be part of a latch assembly.
i've searched the net and this forum to no avail
thanks in advance
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
There was a very good writeup over on VolvoSpeed but I can't find it at the moment. Try using the advaced search over there.
apuig
Year and Model: 1998
Post by apuig »
i've been trying to install a third row seat and researching this same issue. i found a video that shows that all second row seats have the hole for the catch, if its not exposed you have to cut through the lining/carpeting. i did this and found the opening. what i'm not sure of is whether you need the plastic molding to hold the third seat in place. my guess is not - that seems to be a plastic piece of trim that is for aesthetics.
Third seat catch
pafro
Year and Model: 2x V70 R
Post by pafro »
Hi
I have a 3rd seat row on all my 3 V70s..
I will do some pictures this evening.
Have you got any problems with the seat belts or so?
For him: 2005 V70 R AWD & 1998 V70 R FWD manual BSR Stage 1
For her: 2005 S40 1.8
Ex: 850 T5, 850 2.0 20V, S40 T4, 245 2.0 and some others
Pictures here
kidink
Year and Model: 1996 850
Post by kidink »
I recently installed a third row seat in my 1996 850. I cut through the carpet on the back of the back seat (using a regular utility knife) and pushed the plastic piece into place since it's useful in keeping the carpet out of the way of the plastic latch. I don't think the plastic piece serves any other purpose. It's quiet true--all Volvos really do come from the factory with all possible options and bolt holes, and all you need do is make the right attachments.
I've attached a photo of this plastic piece. To keep the upright part of the 3rd row in the upright position, just pull the little strap on the bottom of the upright seat. It causes the lever on the back of the 3rd row seat to pop out so it can insert into the back of the 2nd row seat. When you want to collapse the 3rd row seat, just pull the same strap and the lever releases.
pafro
Post by pafro »
I have made some pictures from the 3rd seat row in my R. Hope it helps.
Pictures here
mrjacobrussell
Year and Model: 2006 s60R
Has thanked: 2 times
Post by mrjacobrussell »
kidink wrote:I recently installed a third row seat in my 1996 850. I cut through the carpet on the back of the back seat (using a regular utility knife) and pushed the plastic piece into place since it's useful in keeping the carpet out of the way of the plastic latch. I don't think the plastic piece serves any other purpose. It's quiet true--all Volvos really do come from the factory with all possible options and bolt holes, and all you need do is make the right attachments.
Does any one have a part number for the piece that goes in the back of the middle row with the slot in it?
2004 S60R AutoX Car
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
2005 v50 t5 AWD for sale
I have a Chinese DICE, works well.
In southern Oregon.
db130
Year and Model: 2002 V70 T5
Post by db130 »
I don't have a part number but I have the part in my parts bin. PM me if you'd like to buy it. It's charcoal in color.
2002 V70 T5 169k
2002 V70 NA 249k
2006 Mini Cooper S 90k
Has thanked: 311 times
Been thanked: 817 times
I don't have the part number either ... but for installing (or removing) the third row seat, here is another write-up with a lot more photos:
https://www.matthewsvolvosite.com/forums ... =1&t=49056&
