I need to replace head. Could anyone tell me what model car has engine compatible with B5254T, 10 compression, LPT and VVT?
Thanks
Compatibility model for engine B5254T XC 1999
andybbrown
- Year and Model: v70 1999
andybbrown
Maybe not 10 compression
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Any Low pressure turbo head with VVT should work-This means XCs, GLTs and LPT C70s. Use the VIN code to help: characters 7 and 8 should be 56 ex: YV1NC56xxxxxx where YV1=Volvo, NC =C70conv. 56 = LPT motor. after that come emissions and serial numbers. I expect 1999-2000 perhaps newer as well. From what I've heard, the head is the same for the N/A cars as well, the compression difference is in the bottom end. If so, any non HPT, single-VVT head should work. edit: basic heads are the same, differences turbo heads use sodium filled exhaust valves. cams are different between variants. If you just need the core head, it looks like your choices open up to any single VVT head.
Current Volvos:
- Year and Model: Lots
- Been thanked: 128 times
Non turbo heads have no VVT in 99 and have VVT on intake (not exhaust) in 2000 and above so beware.
- 358 Views
Last post by combatkarl
- 1206 Views
Last post by jbeebo
