Im getting white smoke from the hood of the car, I've been getting the smoke for a few days now but I've been neglecting it because of time restrictions. Today the coolant light came on. Should I inspect for visible leaks for coolant? Where should I start with this?
The smoke starts to come after the car is warmed up a bit, and persists even at idle.
I'll inspect the oil the next chance I get.
Could this be the head gasket?
1994 volvo white smoke, low coolant
- Year and Model: Lots
- Been thanked: 128 times
Sounds like water may be hittting the exhaust system on its pathway to the ground. There is a coolant pipe running behind the exhaust manifold made from approx 25mm metal tube. Is this a turbo or non turbo?
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Not sure how to respond to this question.daversm wrote: Should I inspect for visible leaks for coolant?
I doubt it's a head gasket issue.
There's a large o ring seal at the end of that water pipe just behind the water pump that may leak though I've only read of one instance. A more likely leak source are the heater hoses and the likelihood of a clamp biting through them.
Also the heater hose coupling at the firewall has small o rings that may begin to leak.
- 1431 Views
Last post by JDS60R
- 2944 Views
- 4036 Views
Last post by MathalomuleM31
- 10 Replies
- 8625 Views
- 785 Views
Last post by tryingbe
