Volvo 850 Wheel Well Liners
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
Wheel well liners, inner fender liners, wheel arch liners call them what you like.
Did these change over the years or perhaps trim level to trim level?
I ask because I would like to replace the liners for the front wheels on my '95 T-5R. I recently bought 1 for the driver's side wheel that came off of a '95 GLT and it did not fit. Do I need to get a set off of another T-5R?
Thanks,
- Marcin
Has thanked: 2197 times
Been thanked: 1850 times
Sorry, but can't answer for an 850, but I thought all 850's and P80's might be the same. I am just about to replace the LH front one on my 2000 V70R with one from a 1999 V70 and they look the same. I will find out tomorrow if my assumption is correct!
What do you see that is different between the 2 you have?
Been thanked: 504 times
Post by cn90 »
PN 9152683, 9152684 fit 1997 and 2000 model years only.
polskamafia mjl
The differences aren't readily noticeable but when I tried to install the "new" one I simply could not make it fit. Comparing the two side by side I noticed a few things, bolt holes in differing locations, certain portions being shaped differently, etc.
You could just phone a dealer, give them the part number, and the should be able to tell you what other vehicles are fitted with the same part. They have a reverse part number look-up facility.
9152683 (LH) that I picked up from a 99 XC fitted my 2000 V70R.
polskamafia mjl
Good idea. I'll give it a try.
Has thanked: 311 times
Been thanked: 817 times
The R front bumper drops down lower than a regular bumper, that must be why the liners are different. Where the liner connects at the back, to the rocker panels, those are the same on a standard 95 or an T5-R 95. Does that make sense with the way the standard liners didn't fit your car, were they fine at the back but didn't match up at the front?
I know the R bumpers are all the same across all of the 850s (95-97), people swap them around all the time. So you will probably need a liner from any R for a perfect fit, that may be hard to find. I have no clue if the 98-00 R liners will fit or not.
polskamafia mjl
Gotcha.
I could never get both the front and back of the liner in which would be explained if the front drops down further. This may very well be the reason.
