I'm replacing some of the trunk area plastic trim in my 2000 V70R wagon, and noticed there is a carpet covering the spare wheel in its recess below the trunk base, but there is no wooden (plywood/hardboard) under the carpet. Do any of you with a wagon know if there should be a shaped piece of hardboard that sits on the polystyrene ring over the spare mini wheel but under the carpet?
Thanks,
2000 V70R - Spare wheel cover?
- Has thanked: 2215 times
- Been thanked: 1853 times
Discovered the spare wheel was mounted incorrectly (up-side down) which prevented the rear floor flap seating properly.
There must be someone out there with V70 of some version, that could take a quick look under the floor cover for me please to see if there is a sheet of shaped hardboard under the carpet over the spare wheel?
Thanks,
Thanks,
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
No hardboard under mine.
Thanks rspi. Seems strange, but appreciate you taking the time to reply.
stephansvolvo
- Year and Model: V70 GLT 1998
- Has thanked: 21 times
- Been thanked: 3 times
I do have hardboard. But I also have the third seat. Might have made a difference
Stephan
84 240GL my first(sold)
88 240GL(timing belt killed it)
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
stephansvolvo
Looks like a yard run is the direct future
Stephan
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
Thanks guys. I had another look at the carpet and it has a padded section that would rest on the spare tire. If I were going to keep the car, I would make a hardboard cover. Just not using the car enough (220km in last 3 months). Boss has said it will have to go.
- Has thanked: 312 times
- Been thanked: 818 times
All of my wagons have had a board.
Well, I have now looked at 6 or 7 V70 P80's in the breakers yards around here and not one had a piece of plywood over the spare wheel. I did find a piece in the back of an 850 Turbo wagon and picked that up. I've posted pictures of the various parts below. Even checked this car at the local dealer. 2000 V70 XC with approx. 75,000 miles (122k km). They are retailing it after replacing the rear diff seals, the front shock mounts and the turbo return pipe. Crazy price though! Oh, and it didn't have the wood cover either. Maybe it was an 850 thing only?
http://www.valentinevolvo.com/preownedv ... d4002965f6
I've fitted the 'plank' which just seems to sit on the tire, it doesn't actually span the wheel well.
- 1184 Views
- 2259 Views
Last post by Richard_TD
- 10 Replies
- 3623 Views
Last post by kaneelschep
- 2063 Views
Last post by VcuYEXw
- 14 Replies
- 2446 Views
Last post by jonesg
