Replaced mount but noticed the horizontal bolt that holds bracket to engine mount with 13mm on left and 15mm on right looks to be way too small for the holes in the bracket and old/new engine torque mount. Looks to be maybe a 10mm bolt and holes look to be approx 1/2 in.
Does this sound correct??? Looks questionable to me. Any response appreciated
LEE
2004 C70 Upper Engine Torque Mount bolt
- Year and Model: Many Volvos
- Been thanked: 76 times
Perhaps the bolt is one from the older style mount. I have never had them side by side but I think the older style press in mount used a smaller diameter bolt.
JRL
- Year and Model: Several
- Been thanked: 16 times
It does not
Did you get the right year mount?
98s are different
98s are different
Tkx for the input... I'd better go to Volvo and check out their parts diagrams. Am new to Volvo and excited about my new-to-me 04 convertible.
Is there any online resource for year or model specific diagrams and parts??
- Has thanked: 311 times
- Been thanked: 817 times
volvopartswebstore.com and other parts sellers have factory diagrams.
- Has thanked: 2197 times
- Been thanked: 1851 times
My 2000 V70 R had the older style mount that mount with 4 bolts to the top of the cylinder head but has the `round` rubber bush which is less durable than the newer `square` style as used on the 2001- P2 models. I had to modify the mount slightly and the brace to the bulkhead to allow the faces to fit neatly. I also noticed the bolt hole was slightly larger. Checked with our 06 XC70 which uses the square mount, and the bolt diameters are nearly the same. Both are smaller than the hole in the mount. This is the way the dealer had fitted it.
So I wouldn`t worry too much about it. If you want a bolt that fits the hole perfectly, you will have to try your hardware store.
- 1713 Views
Last post by kosh_al
- 888 Views
Last post by GreenMagicMan
- 816 Views
Last post by difflock54
- 1926 Views
Last post by rspi
- 51 Views
Last post by vtl
