Restrict your input to 1993-2000 MY vehicles.
Please post *how* it failed (and repeat the exact mileage) in the thread.
Would also be nice to know how often the coolant was changed/flushed.
1998 V70XC, 154,000 miles, no failure (yet).
Coolant flushed every 30,000 miles with the Volvo goods.
At what mileage did your head gasket fail?
mtd240
- Year and Model: 2007 XC70
- Has thanked: 23 times
- Been thanked: 7 times
2007 XC70, white/oak, 175k miles
2008 XC70 3.2L, 115k miles
2016 XC60, osmium grey / off-black, 95k miles
Gone:
1990 240 DL Wagon, M47, lots of goodies. 372,000 miles
1978 242, lots and lots of work to get a reliable daily
1998 V70 XC, Almost done replacing everything, then I sold it
1996 850 NA, victim of sporadic tree falling. Protected the wife. RIP Volvo
Gone:
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
This is NOT a Subaru, these cars do not suffer from failed head gaskets from age. They fail from coolant roulette, people overheating the motor due to coolant loss or water pump failure.
Coolant is good for 5 years or 150,000 miles.
- rspi
Contact rspi..
Oh, I'm at 267,000 and the coolant was replaced 1 year ago at 245,000.
- Has thanked: 311 times
- Been thanked: 818 times
Never had a head gasket fail on a Volvo 850/x70. I've replaced them, when pulling the head for other reasons, but not had a factory one fail.
Mileages of engines I have owned on these cars:
225k
180k
240k
205k
110k
170k
125k
FWIW: Before I got them some of these engines ran green coolant for who knows how many years, some only ran Volvo coolant etc, but I always flush thoroughly then switch them over to fresh Zerex G-05 and change it at 30k intervals.
225k
180k
240k
205k
110k
170k
125k
- Been thanked: 504 times
I thin "rspi" is right, some other makers such as Subaru have that problem: head gasket fails at ___ miles.
The Volvo gasket seems to be bullet-proof until a "bullet" hits it (overheating from massive coolant leak os seized thermostat).
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
No failure yet at 176K miles on our '97 855 GLT. I change the coolant every two years with 50% blue Volvo OEM coolant and 50% distilled water.
JRL
- Year and Model: Several
- Been thanked: 16 times
NEVER wait 5 years or 150K
Every 30K is a good rule of thumb but no later than 60K
mtd240
Cool, good to know that headgaskets are really an "issue" with these. Seems like "lack of maintenance" is the main headgasket killer.
I do it every 30k miles, OEM stuff, for my 240s and XC. Run some plain distilled water for a couple minutes before the final fill. Only costs ~$40 and less than an hour.
Agreed, never higher unless you are using Toyota Red ("Extra Long Life", 120k miles) or even the newer iterations of Dexcool (reformulated, no longer the plastic-eating gunk-causing stuff it once was). I wouldn't feel comfortable doing that in my cars, though. Thermostat will be dead before the coolant change interval is overJRL wrote:NEVER wait 5 years or 150K
Gone:
Gone:
I think head gasket failure has very little to do with coolant neglect.
Below is a nice article by Larry Carley on the causes of HG failure:
http://www.import-car.com/internal-engi ... kets-fail/
Basically it boils down to 2 main causes:
1. Overheating
2. Detonation & Pre-Ignition
1. Overheating
