1995 Volvo 850 GLT
Forum rules
1995 Volvo 850 GLT
133,000 miles - 9/7/2013, New timing belt, idlers, tensioner and water pump. Replaced spark plugs, ignition wires and serpentine belt. Cooling system refilled with new Volvo coolant. Drained 3.5 quarts of of original ATF and re-filled with new ATF (Toyota Dexron III).
2008, C70, 44,000 miles
2000, S70, GLT, 67,000 miles
1995, 850, GLT, 144,000 Miles
1996, 850, Turbo, 226,000 Miles (TMU)
9/15/2013 - PCV service completed. The service successfully corrected the smoke from the dipstick and it no longer blows up the glove placed on the oil fill port.
10/5/2013 - Replaced rear brakes, pads, rotors, R/R right rear caliper (Used). R/R right rear brake pipe (right caliper to flex line), flex line and center brake pipe (flex pipe to left rear junction). Bled rear brakes.
10/5/2013 - rotated tires. Same side front to rear.
12/7/2013 - lost all coolant while driving home from my neighbors house (1/4 mile). Found lower hose clamp snapped (rust) and lower hose off of radiator. Replaced clamp and re-filled with Volvo coolant.
3/28/2014 - R/R turn signal switch with donor part. Pick and pull charged me $26 for the part. I thought that was steep since a new one from eeuroparts.com is $87.
5/10/2014 - new Bosch o2 sensors (front and rear). Front o2 came out with a little effort and Pb blaster, the rear was a different story. Exhaust shop welded in new Magnaflow cat with a new pipe and o2 bung. Waiting to see if po133 code comes back
5/11/2014, Replaced front engine mount with Lemforder mount. LOF with Mobil 1, Mann filter, 10w40, replaced oil cap o-ring. Recharged A/C, no a/c system leaks found.
