2001 V70 Bulb Failure Dipped Beam -bulb, fuse, relay ok
skaupert
Year and Model: 2008 V70
Post by skaupert »
So I have this wretched failed low beam problem, where the light is out, and it's not the bulb, fuse, or relay. There is no power to the socket for the left hand low beam fuse. No power to the light (I've read all I could find, know that there are multiple fuses, checked them all. Checked and exchanged the bulb. Checked and swapped out relays. No difference.)
There was no 'event' that would give any clue as to why it stopped working. On a dry, typical fall day, I took the car out three times. When I started the car for the third drive, the left low beam had stopped working. Bulb is a Sylvania, and less than 2 years old. I always drive with the headlights on.
I'm now looking for a diagram that shows me what each of the relays and shunts on the CEM are for. (the only info I found identifies just the low beam relay and shunt) I'm also looking for a reference that would allow me to test the CEM itself for broken solder points, or issues with its chips.
Thanks in advance for any pointers and/or reference material. I'm also wondering if anyone knows of a service bulletin about this issue that might be of further help.
Thank you!
2008 V70 3.2, 199k, black
2005 XC70 2.4T, 165k, black
2001 V70 non-turbo, 149K, black
Before:
93 240 (01 - 07)
85 240 (96 - 01)
draser
Year and Model: 2005 S60 2.5T
Post by draser »
Can you check fuses 22, 23 in. cem, see diagram?
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
skaupert
Post by skaupert »
Will do! Had no idea there were fuses in there. Thank you, will report back!
Before:
93 240 (01 - 07)
85 240 (96 - 01)
adrian22
Year and Model: s60 2006
Post by adrian22 »
I have same problem in my car S60 2006
can you indicate where are the relays for the low beam headlights?
Thanks
adrian22
93SCMax
Year and Model: 2001 V70 T5 mt
Has thanked: 36 times
Been thanked: 44 times
Post by 93SCMax »
skaupert,
Double check your electrical connector going into the light bulb. I've had this issue a couple of times and had to change out the connector to make the issue go away. With the heat generated in the engine compartment, it degrades the connector and likely turns into an electrical ground or connection issue. Check your relays and fuses, but I'll bet it's a connection. Connectors are cheap, but you will need to do a little splicing. Good luck!
adrian22
Post by adrian22 »
I dont have power at the fuse socket coming from the Relay
But could not find the relay -I am afraid it is embedded in the CPU electrical board
adrian22
