1999 V70 Front Wheel Bearing Mount Bolts
juggles
- Year and Model: 1999 V70
- Has thanked: 2 times
I've stripped a front wheel bearing mount bolt in my '99 v70 and my local dealer doesn't have any in stock. I'm hoping to get the car put back together before the weekend so does anyone know if there is an acceptable replacement that would be more easily available?
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
Measure the threads, typically it will be metric. Did you strip the bearing threads as well?
The dealer usually only takes a day to get stock, I would wait
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
- Been thanked: 504 times
You will be surprised Volvo dealer can order it next day (PN 1387892) and you should have the bolt by Friday (closed Thanksgivings). Dealers order hundreds of parts everyday to fix the customer cars and they can have the part in 1-2 days.
This job requires a lot of work and the bolt head is Torx (not Hex) to clear the axle ring!!!
However, if you insist to do it the ghetto way (which I don't recommend b/c dealer can get the bolt within 1-2 days), then read the posts by Matty Moo carefully LOL!
Just bring your old bolt to local hardware store to get a good match:
https://www.matthewsvolvosite.com/forums ... =1&t=54941
NOTE for others: before doing this job, have a few bolts on standby. Better yet, replace them all.
Photo below is courtesy of Matty Moo, note the "correct" orientation of the Hex head bolt to prevent rubbing against the axle ring!
Matty Moo
- Year and Model: 850, 1996
- Been thanked: 30 times
Lol.... That actually worked perfectly. The head has to be at a certain angle to clear the axle.
I likely wouldn't do that again as I was fed up with that car in general. Everything except the body was corroded.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
JeffHicks
- Year and Model: 1989 240 Wagon,
This is precisely what I resorted to when replacing the hub assemblies on a friend's 850 recently. If I recall correctly, they're 12mm bolts, 1.75 thread, and 50mm in length.
In order to assure adequate clearance of the drive shaft, I smoothed down the "axle side" of each of the bolt heads, with a 4" angle grinder. It worked perfectly.
If anyone ever replaces those hub assemblies again, they are going to be royally confused and POd! But considering that the car already has 250k miles on it, I doubt they'll be replaced again.
1989 240 Wagon, 1999 V70 Base, 2002 XC70, 2005 V70 T5
Ha,
I am OK with ghetto repair but the consequence can be significant. Let's say you hit a big pothole and somehow kill the brand-new bearing, you will be staring at the ghetto hex-head bolt that was rounded off to clear the axle!
So, best is to stay ahead, get a few bolts from dealer (they are $2-$3/each, basically cheap!) beforehand.
The REAR shock absorber mount is similar: get the bolts ahead b/c chances you will break one of them.
Ditto for the Thermostat Housing Torx screws.
My BEST advice: read forums ahead of any job, take note of the cautions.
Now, if you don't want to buy extra bolts, it is fine, but make sure:
a. You call the dealer ahead of time and make sure the relevant bolts are in stock.
b. You work during dealer open hours, this way you can go and get these bolts if needed.
c. Have another mode of transportation (another car, bicycle, bus, or walk) to get to the dealer.
Nothing is more frustrating than doing a tough job on a Sunday, when all the stores are closed and you need the car for work on Monday!
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
Way big-time good advice! I have boxes of nuts and bolts for an AH, a VW, a bunch of different Mazdas, old MBs and a new growing box of nuts and bolts for my 2 Volvos. True life savers on a Sunday evening.
Happy Thanksgiving to all in the US.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
JeffHicks
To clarify, there is nothing "ghetto" about what I did. Roughly 1/8" of one of the "hex lobes" of the bolt heads were rounded. If necessary, removal would be MUCH easier than those silly inverted 11mm-head OEM bolts. Also, the surface contact of the hex-head bolts to the steering knuckle is greater than the OEM bolts - so the strength of the assembly is actually better than new.cn90 wrote:Ha,
Honestly, the OEM bolts used for those hub assemblies was one of Volvo's poorer design ideas. It's almost a guarantee that you cannot successfully remove them.
Actually the Volvo bolts are not bad at all. However, after years in service, the bolt threads are soaked in road salt and develop corrosion.
To avoid stripping the Volvo bolt head, one needs to heat the threads a bit, maybe 30-60 sec with a propane torch aiming from outside directly toward the hub's threaded areas, where the bolts come out (photo in forum).
Once the threads are heated up, the factory Loctite will loosen up.
- Been thanked: 4063 times
I've got leftovers from my FWB job this fall. pM me if you want me to send you the best ones I have to get you back on the road.
- 3212 Views
- 293 Views
Last post by jmartin919
- 1088 Views
Last post by erikv11
- 2943 Views
- 1296 Views
Last post by Nevada1906
