2007 v70 2.5t high pitch noise in engine bay
Driven
Year and Model: V70 2.5t 2007
Post by Driven »
Noise stops when I turn the steering wheel :?:
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
possibly from the power steering pump, usually it has the wrong fluid, flush and use the Pentosin or the Prestone synthetic for european cars
draser
Year and Model: 2005 S60 2.5T
Post by draser »
More info, when has it started, was it related to recent repairs, can you hear standing by engine bay, etc...
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
Driven
Post by Driven »
Thanks for response it has the pentosin fluid has not been flushed ever. No noise now it went away, the only I can say is it was colder here than normal (floriduh) I think it has to do with pump.
Thank you all
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Driven wrote:Thanks for response it has the pentosin fluid has not been flushed ever. No noise now it went away, the only I can say is it was colder here than normal (floriduh) I think it has to do with pump.
Thank you all
Change the fluid.
Driven
Post by Driven »
Replaced power steering pump and now i still have a squealing noise that is definitely related to the steering? The rack?
vtl
Post by vtl »
What kind of fluid did you put into power system?
Driven
Post by Driven »
pentosin, I have 225,000 miles on the car. I was wondering if the noise could come from the steering rack?
vtl
Post by vtl »
I'd check everything else driven by aux.belt - load on it varies a bit when you turn steering wheel. Dry bearing make squealing sound.
Driven
Post by Driven »
I will check it again thanks for your help!
