Volvo 850 Rear wheel do not free spin
Baptiste1106
- Year and Model: 850 1994
- Been thanked: 2 times
I noticed my rear axle wheels do not free spin. I replaced my rear rotors w/ EBC Rotors & redstuff ceramic pads along w/ SS brake lines from fcpeuro.com. It seems the previous owner put new hub/wheel bearings on both rears. So either the Hub nut is to tight or one of the pistons on each caliper is stuck in the open position. Any thoughts MVS?
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Did you try to spin the axle with the wheel on or off?
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Is the emergency brake adjusted overly tight?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
Baptiste1106
@ Rspi ... Tried to spin wheel with tire off...
@ E Showell... Never checked E brake and last I looked at them, they needed replacement anyway
- E Showell
You could have a frozen Ebrake. It does happen.
'95 855 auto (sold)
'95 855 auto (sold)
- rspi
Contact rspi..
Try with the wheel on. It is always hard for me to rotate the wheels axels with the wheels off.
shaker_chi
- Year and Model: 94 850, 98 S70T5 M
- Has thanked: 3 times
- Been thanked: 3 times
First thing I would check is the adjustment on the e brake. Even when its adjusted properly you will have some slight rubbing. Take some slack off and see what happens.
In likelihood of occurrence
Frozen caliper - looking at your pix and NYC location - I would go with this at 93% probability
Sticking emergency brake - usually happens if it isn't used regularly, and then used one day.
Seizing wheel bearing - almost always accompanied by nasty noises in wheel.
- 1588 Views
Last post by darylrobert
- 632 Views
Last post by jonesg
- 916 Views
Last post by greg850r
- 23 Replies
- 10650 Views
Last post by zupta82
- 1493 Views
Last post by zimbodel
