Alright you guys. I do not want to accept this "Hiccup" stuff.
Just kidding. I have already experienced it while purchasing my '98 XC.
I was thinking it may be the SAS. I will install some nearly new OEM Bosch O2 sensors shortly, as well as a decent cleansing to the MAF.
Michigan does not care about SAS. Nor do I. I will likely take that out of the equation.
I have several ECUs to chose from in storage. I understand there is a jumper that needs to be soldered.
I was thinking of throwing one of my "R" 628 ECUs in there to see what would happen.
Do not really want to kill the car just yet.
Work in progress.
1998 v 70 awd 256 k 6 codes, runs fine
Ben850
- Been thanked: 7 times
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
I don't believe it's the SAS. My mechanic took the SAS out of his car a while ago (98' XC just like mine) and I'm pretty sure it's still doing the hiccup. I will check with him to make sure.
But the SAS delete is on my "to do" list as well. My pump is making a lot of noise and is probably on it's way out.
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
Ben850
Please let me know how that goes.850 LPT wrote:I don't believe it's the SAS. My mechanic took the SAS out of his car a while ago (98' XC just like mine) and I'm pretty sure it's still doing the hiccup. I will check with him to make sure.
Here is my new bank drain.
I wouldn't really be doing this if I did not enjoy it.
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Got a thing for white, I see.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- 850 LPT
Congrats, you bought the exact clone of my car. Even the interior color is the same.
If it behaves anything like mine, it will drain you bank account alright. Especially if you want to keep the AWD alive.
Good luck with it! (No sarcasm here, I really mean that)
Dirk
Dirk
13' Honda Odyssey
13' Honda Odyssey
obayha
- Year and Model: V70 1999 Base
- Been thanked: 2 times
I have seen a lot of posts on this hic-up lately.
About a month or so ago I changed my radiator, had been leaking for ever. Decided to check the play in the inlet side of the turbo, because I was having oil on the back wind screen. Well it turns out, you need to check the other side for play, from what I was told. Anyway, put everything back together and on it's first ride to work, at the near end of my 50 mile ride the car did the hic-up. Never ever had that done to me until that day. Thought the motor was coming out of the hood. Ran an OBDII on it last week, about a month after the first hic-up, and codes were misfire on all cyl. except number 4 and massive evap leak.
It does the hic-up everyday, at least 3 or four times to and from work. SAS has been deleted a few years back with the diode, so I don't think that is the problem.
I am running on borrowed time with this car and looking for another one.
I figured maybe I bumped something in the replacement of the radiator or messing with the inlet turbo. Anyway just adding to this post with same type problem and looking for a solution.
Shane
PS On a good note, The radiator works great, haven't had to fill it up in over a month. Fix something, something else breaks.
Shane
1998 V70 T5 331,000
Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
I would say they are more time soakers than cash soakers. German cars are the real cash soakers, I find parts for these cars to be reasonable. No more than a Japanese car. The driving experience and the fact that most of the problems are DIY make up for it.Ben850 wrote:Please let me know how that goes.850 LPT wrote:I don't believe it's the SAS. My mechanic took the SAS out of his car a while ago (98' XC just like mine) and I'm pretty sure it's still doing the hiccup. I will check with him to make sure.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
Ben850
Of course when I said cash soakers, you know I mean that I personally like to spend money on them.
As far as time, It is also a hobby so it is enjoyable to me these days.
I am not complaining.
The fact is, these cars have brought back my interest in form and function with regard to automotive design.
jaymorgan1
- Year and Model: 98 v 70 awd
I had a loose turbo to exhaust flange and the rubber hose to the hard pipe and intercooler blew. The car ran no different after I repaired these. That should tell me something but I am not sure what.
The cat is rotten at the back side and leaks a little, will this cause these codes ? With the high mileage I was just going to JB weld a repair to see if it affected anything.
I would like to post a picture of this gem, quick tutorial anyone ? I have a pic saved to my pictures at this point.
Thanks
Thanks
- 799 Views
Last post by rspi
- 1172 Views
Last post by dosbricks
- 21 Replies
- 11546 Views
- 1915 Views
Last post by volvolugnut
- 1270 Views
Last post by peacelover60
