2000 S40 inner tie rod removal and replacement
siegwam
Year and Model: 2000 S40
Post by siegwam »
Anybody remove inner tie rods on a 2000 s40? I have been told by two shops that their computer programs are telling them that the rack and pinion need to be removed in order to remove inner tie rods. Is this correct? I know I can do it if I have the inner tie rod tool to remove them but I don't want to do this if I have to remove the rack and pinion. Any info on this job anyone can give me would be great! Very frustrated at this point. Outer tie rod ends seem to be fused on. Couldn't get the retaining nut loose at all. At this point they are going to have to be cut off.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
For the outer tie rod nut, I put an adjustable wrench on the nut and a wrench on the outer tie rod near the bolt, so the two wrenches sit like a scissor. then forced a cheating bar in between the two while keeping both wrenches together with one hand, so as to 'open' the scissor
maybe this can be of any help? http://www.volvoxc.com/0/resources/how- ... e-rods.pdf
siegwam
Post by siegwam »
Thanks for the response! Should be a big help.
