2002 volvo s60 stalls after restart while warm Topic is solved
Vovo_merz
Year and Model: 2007 s60R
Post by Vovo_merz »
Hello Volvo fans, I am new to this particular forum so if I say or do anything to offend anyone I would like to apologize in advance. now down to the problem I am experiencing
Its a 2002 S60 2.4T I just got the car so do not know the back story all I know its been sitting for a while
I have put about 100 miles since getting the car and after driving few miles and vehicle being warmed up and when I try to restart the engine it will die right away no matter how many times you start it, if gas pedal is pressed the vehicle will stay running until let go, if I give some gas then try to drive it, it will drive normal and will not stall while in gear and drives fine, also while starting in the morning or when engine is cold the car starts just fine and stays running, so my problem only happens when the car is warm and is being turned off then back on.
No check engine light
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Find somebody with DiCE and read the codes. Or at least read them with OBD-II reader.
draser
Year and Model: 2005 S60 2.5T
Post by draser »
Have you done a one over to see general maintenance condition, plugs look clean?
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
Vovo_merz
Post by Vovo_merz »
car was a bit of a mess when I got it, so i did a stage 0, and again the car runs great while in drive or when started cold
1995 - 850 1st
1995-97 - 850 R 3 Black, Red, Yellow
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001 xc70 (wifes first car)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
1998 Merz $500 custom
2009 Merz $550
2013 chevy 2500HD
draser
Post by draser »
What I was getting at was that maybe you noticed the plugs were smoked indicating a rich condition coming from a defective coolant sensor, which explains your symptoms.
Vovo_merz
Post by Vovo_merz »
this coolant sensor you are talking about, is it the one next to thermostat?
1995 - 850 1st
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
2009 Merz $550
2013 chevy 2500HD
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Yeah that coolant sensor is built into the thermostat housing on 2002s and will be a PITA to remove. I bought one for our 2002 XC (also an LPT) & haven't been able to muster up the courage to do the job.
Also expensive at over $80 landed (I bought an Italian made Beck Arnley from Amazon) so you would want to look at Torque with ELM327 as a minimum before investing in a new housing.
Coolant temp while warm is easy enough to read on any obdII scanner.
Vovo_merz
Post by Vovo_merz »
will look into that sensor, should have one laying around somewhere
thanks Mike
1995 - 850 1st
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
2009 Merz $550
2013 chevy 2500HD
draser
Post by draser »
You could put a meter to it, set on ohms, engine stopped and harness unplugged. It should read over 1000 ohms engine cold and a few tens of ohm engine hot. Someone may know exact ohm readings, but my ball park range will give you an idea. Or you could use a code reader as said. Many ways to skin a cat...
Vovo_merz
Post by Vovo_merz »
while I was waiting for the weather to clear up a bit the car stalling solved it self for now will have to drive a bit more to see if it comes back
1995 - 850 1st
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
2009 Merz $550
2013 chevy 2500HD
