not sure what the problem is. was driving on the highway at 65 mph. seems as though it wouldn't hold speed while going up minor inclines, would drop down a gear to get back up to 65.
then, all of a sudden, lost power all together and the car stalled. i was able to coast over to the shoulder. now it won't start. it seems the starter is spinning but not engaging with the flywheel.
i have the following codes,
644A
4801
6806
3000 camshaft position sensor
the first 3 i have been battling off and on. the 3000 i have never seen before.
any thoughts are greatly appreciated.
2000 v70xc car died and now won't start
mrscullini
- Year and Model: 05 XC70, 08 XC70
mrscullini
sorry, i've got about 213k on it. at about 185k, i had burned a valve and pulled the head to repair. it seems to have run great for about 30k, until today.
mrscullini
after a little research, i suspect that 644A and 3000 are related. both cam codes. wondering if the 644A caused the 3000.
is the cam shaft position sensor located under the torque mount? is there a way to test this sensor?
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
The fact that the starter doesn't spin the flywheel, could have the flywheel lost some teeth? The timing belt is still at the marks?
mrscullini
thx. that thought crossed my mind. i haven't had any starting issue, no have i crashed the bendix into the flywheel with the motor running. so i'm hard pressed to think i lost teeth on the flywheel. i tend to think the bendix may have failed with 213k on it.oragex wrote:The fact that the starter doesn't spin the flywheel, could have the flywheel lost some teeth? The timing belt is still at the marks?
i tend to think that the starting issue and the stall out issue may be unrelated.
I think you will have to resolve that Bendix is due first, then start with the "no start" thread
mrscullini
thx. update....i thought it was the bendix not engaging because when trying to start it sounds like the starter is just spinning, not cranking the motor. well...the motor is turning, i look at the camshafts and they are advancing each time i try to start.abscate wrote:I think you will have to resolve that Bendix is due first, then start with the "no start" thread
with the motor spinning so freely, it makes me think i've lost compression on all 5 cylinders. what are the chances of this happening all at once?
i burned an intake valve last year, had the head tested, reworked and the valve replaced. even with a burned valve the motor would run. i think this is much worse.
thoughts????
Sounds like my '95 when it gets "lawnmower syndrome" . My fix is to have the battery jumped to a running vehicle and then crank the car over with the gas pedal to the floor. I crank for very long periods of time, I have never timed it but maybe up to 30 seconds or more. Others pour oil in each cylinder to cure this. to avoid this I am very careful not to start this car and stop it before it runs for a while. Search this forum for lawnmower syndrome. RSPI has a video on it as well.
2008, C70, 44,000 miles
2000, S70, GLT, 67,000 miles
1995, 850, GLT, 144,000 Miles
1996, 850, Turbo, 226,000 Miles (TMU)
The only thing that concerns me is that you were already driving when this happened. My problem was always initiated by starting a cold engine and then shutting it back off without letting it warm up...but here is a link to a video:
https://www.matthewsvolvosite.com/forums ... =1&t=18175
http://www.google.com/url?sa=t&rct=j&q= ... 3UVLEeH6lg
mrscullini
thx. this is the first time hearing about the "lawnmower syndrome", go figure. from doing a quick search, like you said, it seems that condition occurs on a cold motor. i was up at normal operating temp. i'm going to pull the plugs and do a compression test. i suspect the compression is very low. wondering if my 644a and 3000 code that the cam timing is off holding a valve slightly open on the compression stroke?Rbaratt wrote:The only thing that concerns me is that you were already driving when this happened. My problem was always initiated by starting a cold engine and then shutting it back off without letting it warm up...but here is a link to a video:
- 928 Views
Last post by misha
- 110 Replies
- 17473 Views
Last post by bmdubya1198
- 2719 Views
Last post by mf70
- 15459 Views
Last post by Sea30
- 879 Views
Last post by Dashiel
