1999 Volvo V70 AWD with awd issues
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
The only interest I have in the vehicle is to fix the AWD before giving it to my mother. She already has a fwd car.
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
I won't dispute AWD > FWD in winter
But FWD with snow tires >>>> AWD and all season tires
AWD does nothing for braking traction. First snow fall and it's mainly Jeeps in the ditches, too overconfident in electronics and AWD and no season tires
Scot850: I've heard about all weathers, let us know how they work. I'm dying to wear out my all seasons so I can get some proper summer tires.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
- rspi
Contact rspi..
Finally got the key last night so I'm going to see if the car can be driven. If so, I'll post back what I feel/hear. At that point I will need repair guidance. I'm prepared to order a shaft from CDS, hopefully it won't need much more than that.
- rspi
Contact rspi..
Hmmm, what does this mean? I was thinking about , ordering a shaft today, pulling the shaft that is now on the car and driving it a few days until the new/ replacement shaft arrives, then installing the replacement shaft. What does "load" mean? Will that make installing the replacement shaft harder after driving the car with the shaft removed?Ozark Lee wrote:...since the VC and the transfer case gets unloaded when the shaft is removed.
- Year and Model: Many Volvos
- Been thanked: 76 times
I guess the best way to try to explain what I was trying to say is that the AWD components, without the prop shaft installed, aren't either exerting any torque or having any torque applied to them. All of the AWD stuff basically freewheels without the shaft tying the pieces together.
- rspi
Contact rspi..
Finally went and cranked the car up tonight. Move it just a few feet because the noise it made was real bad. It also felt like the shaft or something up front was moving around and maybe tapping on the bottom of the car. Listen and tell me what you guys think. The replacement shaft should arrive tomorrow. (I'm also having new tires installed tomorrow morning).
- Has thanked: 2205 times
At that speed I would suggest that it sounds like the center bearing carrier in the prop-shaft has probably failed. It is possible the front prop bearing at the angle gear is bad or the rear bearing of the angle gear. If it was the VC or anything back of that I'd be surprised.
- rspi
Contact rspi..
So a replacement shaft will likely cure the problem?
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
When you drive the car, is there a rhythmic jerking of the rear wheels going on at the same time you hear that popping noise?
If that's the case then the VC is locking up and the new drive shaft will not be the cure.
I sure hope that's not what's happening,
Dirk
Dirk
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
- rspi
Contact rspi..
Drive? I could barely move the car.
- 9 Replies
- 1901 Views
Last post by leapdragon
- 11 Replies
- 2577 Views
Last post by dimataeus
- 11 Replies
- 6054 Views
Last post by oragex
- 12 Replies
- 1794 Views
- 382 Views
Last post by Ozark Lee
