My heat works fine, on the driver's side only. Passenger side, air does blow out all vents, but it is consistently cool, not at all hot. VIDA gives me no codes about any of this.
But it seems clear that the barn doors are NOT diverting air for the passenger side over the heater core, but are doing so for the driver's side.
I have this diagram, perhaps there is a more detailed one somewhere in VIDA:
https://www.matthewsvolvosite.com/forums ... =16370&t=1
I removed the glovebox and the panels in the passenger footwell, and removed the servo that is directly below the large white wheel, the one flagged with the grey square in the diagram image, the middle of the 3 at right. When I turned the temperature control for the passenger side low and high, it moved back and forth, and I could manually turn the plug into which the rotating spindle fits, but I could not see to verify that a barn door was actually opening and/or closing.
Any clues that anyone could offer to how to see the barn-doors work would be a big help, as would a definition of which servo does what of the 3 on the passenger side.
Thanks!
2001 v70 Fan Blows Air, But Not Hot On Passenger Side
- packetfire
- Year and Model: 2010 v50 2.4i
- Has thanked: 17 times
- Been thanked: 30 times
1982 240DL: Drove it 32 years and 1.5 million miles (sold, even still had mint leather!)
2001 v70 2.4T: The most expensive $1500 car I ever bought ("Volvo Turbo" - what an oxymoron!) (sold)
2004 v70: Far less fatally-flawed v70 - It served well (sold)
2010 v50: Smaller, slightly sportier wagon. Its got a spoiler, so I upgraded with sway bars!
Do you have manual or electronic climate control?
There are several threads on this problem which I will seek
- packetfire
The 2001 v70 was the first year of the "P2" chassis, with electronic, dual-zone climate control, so driver and passenger each have a temperature knob on the center console. Further, there is a single temperature sensor, behind a small grille built into the Climate module in the center console.
- packetfire
An update after further poking into the situation:
1) The lowest servo on passenger side of center console closest to the rear of the car is the correct servo. Turning the passenger temp knob warmer makes the servo rotate its rod toward the rear of the car, turning the passenger temp knob colder, makes the servo turn its rod towards the front of the car.
2) Removing the servo motor and turning the plastic socket into which the rod fits with a 3/8ths socket wrench extender bar results in a satisfying audible thump when the door hits the limits of its travel.
But while the fan blows air out of the passenger-side center console, dash-by-door, foot, and windshield defroster vents in accordance with which selections one makes on the climate control unit, this air is never warm, never hot. Driver's side is hot, as it should be. In all of these tests, A/C is disabled, so the cool/cold air is not being chilled by the A/C unit. Air volumes and velocities coming out of the vents seem equal between driver's side and passenger side, holding a hand in front of each to guesstimate volume and velocity.
So, I am completely stumped here, and I am wondering what I can do, short of pulling the entire dash and pulling the ductwork box apart to watch the doors move with my own eyes.
Any clues, anyone?
Any clues, anyone?
draser
- Year and Model: 2005 S60 2.5T
- Been thanked: 2 times
Any way you could look at driver side range of motion cold to hot to compare to passenger's? Cabin filter clean?
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
DGM
- Year and Model: V70 2.4i 2005
- Been thanked: 3 times
The cabin temperature sensor can get dirty on these models. The little fan inside gets stuck by lint accumulation. Be careful of the pin head device behind the grill it is very fragile. In severe case the fan housing must be removed, disassembled and cleaned.packetfire wrote: Any clues, anyone?
https://www.matthewsvolvosite.com/forums ... =9&t=48562
See the comments of "oilburner" in the following post;
http://www.volvoforums.org.uk/archive/i ... 63988.html
Here is how to remove the climate control unit. It is important to disconnect the battery otherwise you may trigger error codes;
V70 2005 2.4i 195,000km, sold
S70 1998 T5 355,000km, sold
960 1994 80,000km, sold
760 1990 Turbo 265,000km, sold
- packetfire
Never found a solution on this... is there any way to see the barn doors open and close that involves less work than pulling the entire dashboard? From a servo point of view, all seems fine, but the passenger side gets no heat. The passenger side DOES get fine A/C which stumps me. The sensor in the CCU is clean, and the fan seems to turn easily when I blow on it with canned air, so it is not gummed up.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
I've noticed that that from drivers side, if you remove the plastic on the left side of the center tunnel, then the trim above driver's legs (two torx screws), you can get a view at some of the mechanism that opens the a/c duct.
Didn't read all the responses you got and sorry if someone already suggested this but it sounds like you need the climate control system calibrated anyone with vida dice or dealer can do it, had exactly the same problem like yours only on A/C one side didn't blow cold but heat worked on both sides, and works like a charm after calibration
1995 - 850 1st
1995-97 - 850 R 3 Black, Red, Yellow
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001 xc70 (wifes first car)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
1998 Merz $500 custom
2009 Merz $550
2013 chevy 2500HD
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
2009 Merz $550
2013 chevy 2500HD
You could drill a hole into the climate system, then plug it when done with a plastic plug.
Inspect the barn doors with a fiber camera scope. I'm not sure you can fix anything this way but you could at least diagnose.
Alldata reports 9.8 hours for an evaporator core R/R so it's a weekend job to get the climate system out and sorted.
