1998 volvov70 p0455 code
rmmagow
Year and Model: V70 1998
Post by rmmagow »
Your battery or its connections are no good. If there is any corrosion at the battery terminals it won't charge properly either. Check all connections, especially ground for the negative connection. Check the B+ cable too. The noise you heard is probably the secondary air system, the pump for that is under the battery.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
tom4342
Year and Model: 1998 v70 awd
Post by tom4342 »
rmmagow wrote:Your battery or its connections are no good. If there is any corrosion at the battery terminals it won't charge properly either. Check all connections, especially ground for the negative connection. Check the B+ cable too. The noise you heard is probably the secondary air system, the pump for that is under the battery.
Im leaning towards the battery not sure how old it is was in the car when i bought it in 2012 i just replaced the positive terminal and cleaned up the negative, both my cars battery goes belly up at the same time.
Tom Hood
tom4342
Post by tom4342 »
let it trickle charge all night had 13 volts this morning plenty to crank would just thump at the end of the crank,ive ordered a crank sensor,new cam sensor,cap,rotor ignition coil and wire.
Tom Hood
tom4342
Post by tom4342 »
defiantly no spark
Tom Hood
tom4342
Post by tom4342 »
Virtually nothing at contact points when i crank maybe 1.3 volts
Tom Hood
tom4342
Post by tom4342 »
replaced the coil again and the coil to cap wire fired right up, did not suspect the coil because i had just replaced it this summer. I'm doing a full tune up anyhow,plugs,wires,cap,cam sensor,crank sensor got good deals on the parts less than 200 for all.
Tom Hood
tom4342
Post by tom4342 »
Back to square one with the dam p0455 leak grrrrrrrrrrrrrr
Tom Hood
Has thanked: 311 times
Been thanked: 817 times
Smoke test is the only way to find it without checking lots of stuff. Hoses on top of gas tank are another common problem.
tom4342
Post by tom4342 »
Those hoses accessible?
Tom Hood
Did you check if the purge valve is operating correctly? https://www.matthewsvolvosite.com/forums ... =1&t=27538
For the hoses on top of the tank they are a hassle. Here is a thread with some info but by far and away the best way to do this is to empty the fuel tank and drop it down. The tank is light when empty, it is not a bad job. https://www.matthewsvolvosite.com/forums ... =1&t=60269
