2007 S80 Front end suspension clunk
ninefiveone
- Year and Model: S80 2007
My S80 has a intermittent front end clunk I have worked all the TSB's and its still present, its more noticeable when the weather is cold outside under 50 degrees.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
The upper spring seat is a common issue. Also check the upper strut bolt (under the hood) is well tight. The torsion bar end links are also known to fail and get noisy.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
The P3 platform models do not have the same upper spring seat and have no issues with that as a result.
The other suspects that can be noises on P2 models can also affect P3 models but usually at much higher mileage. Check the upper strut bearing plate, the sway car connector links, and see if there is any indication of the subframe mounts moving in subframe (even though the TSB's have been done).
When does it do the clunk?
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
Pertinent question!jimmy57 wrote:...
ninefiveone
Sorry it took so long to respond Im a newbie hopefully Im doing this right. I have had new struts installed the sway bar ends checked out. The noise happens on both sides usually just going up or down a driveway at slow speeds it does not make the clunk all the time that what makes hard to find. The ambient temperature seems to have a lot do with it in the summer the clunk pretty much disappears when the weather turns cold it reappears. Thanks hope this answers the questions presented
jimmy57
That is a known issue with early P3's when the front suspension is twisted. One side will get loaded and the other side gets unloaded when you turn off the street into a raised driveway. It is related to the subframe mount bushings. Who worked on the car and performed the TSB fixes?
The P2 S80 (99-06) does share the spring seats with 2003-2014 XC90.
The 2007-> S80 uses a different strut design with a different spring seat and strut bearing design.
ninefiveone
I have a independent Volvo shop I deal with I have built a trusting relationship with the shop they are also stumped by the clunk. I have some questions to run by them on Monday I'll keep you posted.
- 1836 Views
Last post by estrekal
- 33 Replies
- 11089 Views
Last post by bmdubya1198
- 11 Replies
- 3326 Views
Last post by michaelunderway
- 371 Views
- 871 Views
Last post by Steve H
