1998 v 70 awd 256 k check turbo boost ?
jaymorgan1
Year and Model: 98 v 70 awd
Post by jaymorgan1 »
How do you know if the turbo is working - I do not hear or feel any spooling up. Car runs fine, gets 20 mpg average. In a previous post I listed 6 codes it is currently throwing.
Thanks
1998v70xcbill
Year and Model: 1998v70xc
Been thanked: 3 times
Post by 1998v70xcbill »
I have a v70xc 1998, never checked boost yet. My wish list is a installed gauge. Very easy to add a temporary gauge to manifold and run in car. My car has so much power I assume the turbo is working. I don't hear the turbo spool up. I have 200k. The turbo's on volvo's seem reliable. I checked the turbine for play at inlet. I do have oil dripping from turbo. To cold to deal with now. No drips on ground.
jaymorgan1
Is there a port to tap into as to avoid drilling and tapping ?
Thanks for the info
1998v70xcbill
Yes, I would connect to Intake manifold (after throttle valve), There is a plastic mini manifold (just after Throttle valve) with ports blanked off with rubber caps.
Has thanked: 311 times
Been thanked: 817 times
1998v70xcbill wrote:Yes, I would connect to Intake manifold (after throttle valve), There is a plastic mini manifold (just after Throttle valve) with ports blanked off with rubber caps.
That mini manifold is sometimes called the vacuum tree, I agree that's a good place to hook up a boost gauge.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Every turbo car should have a boost gauge. They sell ok gauges for as low as $15 on eBay. If you don't have one you really have no idea is the system is functioning properly. You can be under boosting (taking performance away) or over boosting (risking destroying your motor).
rspi
Post by rspi »
