99 c70 random dieing
HulkC70
Year and Model: C70 99/00
Post by HulkC70 »
So I'm a bit confused.... is the ICM and the ETM the same thing?
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
HulkC70 wrote:It's a pretty easy install if I remember correctly. The etm is what sits on the passenger side fender under the hood in the black box correct?
Nope...as far as i can see...you're talking about ECU(s).Engine & transmission(if it's auto).
They are at the location you discribed.
ETM is Electronic throttle module and it should be downstream of air filter plastic ribbed pipe where it connects to engine(as far as i remember)...but it's definitely on the air filter line on the engine.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
The OP has a turbo C70 so the ETM will be located on the end of the long plastic intercooler hose under the intake manifold.
On turbos the air cleaner goes directly to turbo inlet via MAF.
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
Hulk, your ETM is a throttle module, it's the fly-by-wire equivalent of a throttle body. Instead of a cable, your throttle is opened electronically. Last stop for air into the intake manifold. ECUs are in the box with the cooling tube.
Current Volvos:
Redneck
Year and Model: Volvo 854 1996 GLT
Has thanked: 10 times
Post by Redneck »
What happens when the car is dieing?
HulkC70
Post by HulkC70 »
Ok I'll try changing out the ETM when I have time this weekend and keep everyone posted on development because if it doesn't work it's back to the drawing board for me.
If you swap out one from an auto chances are it won't work. You need one from the same engine AND transmission.
HulkC70
Post by HulkC70 »
That's going to be very hard to find... There is not that many manual trans 99 c70 of that year... any suggestions? I have a pretty rare car to my knowledge
You just need another good used ETM, a Dice (you don't need Vida at all) and then you contact MVS member doublebug; he will do the rest.
FLXC90
Post by FLXC90 »
Would it need to be C70? shouldn't any 1999, 70 series manual trans/HPT ETM work? (or LPT, I forgot which you have)
Current Volvos:
